Collector crashes when using By Layer search
3729
11-02-2015 01:06 PM
TimothySandstrom
All of a sudden my web maps are crashing when using them in Collector and having web map set with searching by Layer.  When clicking search and entering a string Collector shuts down.
When using the web map with a desktop browser it seems to work just fine.
When disabling search by Layer just using search by Address Collector does not bomb out.
Lastly, when using the Explorer app I have no issue using searching by layer which points the finger at Collector.
Need help ASAP...logging ticket with ESRI soon but thought would share in the GeoNet environment as well.
CurtPope
We found a work around. I had to enable the pop-ups on the layer i was trying to search. The app quit crashing after I did that.
TimothySandstrom
Update, it appears if publish a hosted service and use as a searchable layer there is no issue.
However, this was not the case in the past.  Do not understand why this is happening.  Logged ESRI ticket...
CurtPope
TimothySandstrom
Hey Curt.  I should have replied back to my own topic a few weeks ago.  Yes, working with ESRI we found if pop-ups were enabled the search functionality would work.  What happened was I had to nuke my old service and bring in a new one.  I didn't do all the popups like I had done on the previous service so as result, I had the bug.
Case closed...look forward to a permanent fix.
BryceBeyers
Has anyone figured anything else out on this? The app is crashing for me and I have enabled pop ups for all layers I'm searching on.
