Arcmap FindField to list vb.net
2725
10-31-2015 07:21 AM
SigurdurGear
Hi
I am try to add FindField to list it work well on small area but if I zoom out and select bigger area
I get only 0 to the list not the number in the field
     Dim pMxdoc As IMxDocument
        Dim pMap As IMap
         pMxdoc = My.ArcMap.Document
        pMap = pMxdoc.FocusMap
        Dim pLayer As IFeatureLayer
        pLayer = pMap.Layer(3)
        Dim pFS As IFeatureSelection
        pFS = pLayer
        Dim pEnumFeature As IEnumFeature
        pEnumFeature = pMxdoc.FocusMap.FeatureSelection
        Dim pF As IFeature
        pF = pEnumFeature.Next
        Do Until pF Is Nothing
                     On Error Resume Next
            iList.Add(pF.Value(pF.Fields.FindField("TYPENUMBER")))
        Loop
FreddieGibson
Honored Contributor
From what I understand you're trying to find the values of selected fields and append them to a list. Do you have a dataset you can upload that can be used to replicate this issue? Also, can you replicate the same issue when using a search cursor with a spatial filter?
