Draw area with the Summarize Nearby
1581
10-22-2015 05:52 AM
FrankVignati
Using the Summarize Nearby widget is there a way to set it to only summarize objects from one layer that intersect another layer? On the app the Draw widget has been configured to add the draw to usable layers, and when using the Summarize Nearby in the Analysis widget the selection layer is set to Areas, for the new polygon drawn, the distance is set to 1 Feet and the expected result is tahe only objects from the layer to summarize within one foot of the drawing would be used, but that's not the case.
