template error with jquery ui
3515
10-18-2015 07:34 PM
abukhan
I tried to work with geosearch-template from
Esri/bootstrap-map-js · GitHub
However I wanted to add
<script src="//code.jquery.com/ui/1.11.1/jquery-ui.min.js"></script> after the jquery script reference
and I get the error like this(shows in firebug in firefox).
Error: multipleDefine
d()/3.14compact/ (line 5)
Ja()/3.14compact/ (line 27)
Xa/<()/3.14compact/ (line 28)
a()/3.14compact/ (line 5)
Xa()/3.14compact/ (line 28)
pa/g()/3.14compact/ (line 25)
r.injectUrl/f<()
The reason I wanted to add the jquery-ui reference, so that I can use some function from jquery-ui (like dialog()).....
Here is my complete page code:
<!DOCTYPE html>
<html lang="en">
  <head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no">
    <meta name="description" content="">
    <meta name="author" content="">
    <link rel="shortcut icon" href="../images/favicon.png">
    <title>Geosearch Template for Bootstrap</title>
    <!-- Bootstrap core CSS -->
    <link href="https://community.esri.com//maxcdn.bootstrapcdn.com/bootstrap/3.3.2/css/bootstrap.min.css" rel="stylesheet">
    <!-- Custom styles for this template -->
    <link href="geosearch-template.css" rel="stylesheet">
    <!-- Bootstrap-map-js -->
    <link rel="stylesheet" type="text/css" href="https://community.esri.com//js.arcgis.com/3.13/esri/css/esri.css">
    <link rel="stylesheet" type="text/css" href="../../src/css/bootstrapmap.css">
    <style type="text/css">
      #mapDiv {
        min-height: 100%;
        max-height: 100%;
      .simpleGeocoder {
        margin-right: 5px;
      /* Option 2: Geosearch in nav;
      .simpleGeocoder .esriGeocoderContainer {
        width: 180px;
      .simpleGeocoder .esriGeocoder input {
        width: 118px;
      @media (max-width: 767px) {
        .navbar-form .form-group {
          float: left;
        .simpleGeocoder {
          margin-right: 7px;
    </style>
    <!-- HTML5 shim and Respond.js IE8 support of HTML5 elements and media queries -->
    <!--[if lt IE 9]>
      <script src="../bootstrap_v3/docs-assets/js/html5shiv.js"></script>
      <script src="../bootstrap_v3/docs-assets/js/respond.min.js"></script>
    <![endif]-->
  </head>
  <body>
    <div class="navbar navbar-inverse navbar-fixed-top">
      <div class="container">
        <div class="navbar-header">
          <button type="button" class="navbar-toggle" data-toggle="collapse" data-target=".navbar-collapse">
            <span class="icon-bar"></span>
          </button>
          <a class="navbar-brand" href="#">Geosearch</a>
        </div>
        <div class="collapse navbar-collapse">
          <ul class="nav navbar-nav">
            <li class="active"><a href="#">Home</a></li>
            <li><a href="#about">About</a></li>
            <li><a href="#contact">Contact</a></li>
          </ul>
          <!--Option 1: Modal-->
            <li><a id="geosearchNav" href="#">Geosearch</a></li>
          </ul>
          <!--Option 2: Insert in nav bar-->
          <!-- <form class="navbar-form navbar-right">
            <div class="form-group">
              <div id="geosearch"></div>
            </div>
            <button id="btnGeosearch" type="submit" class="btn btn-success">Search</button>
          </form> -->
        </div><!--/.nav-collapse -->
      </div>
    </div>
    <div id="modaldialog">Hery I am here</div>
    <div class="modal fade" id="geosearchModal" style="display: none;" aria-hidden="true">
        <div class="modal-dialog">
            <div class="modal-content">
                <div class="modal-header">
                  <button type="button" class="close" data-dismiss="modal" aria-hidden="true">×</button>
                  <h4 class="modal-title">Geosearch</h4>
                </div>
                <div class="modal-body">
                  <form id="geosearch-form">
                    </div>
                    <button id="btnGeosearch" type="button" class="btn btn-success" data-dismiss="modal"> Go </button>
                    <button id="btnClear" type="submit" class="btn btn-default" data-dismiss="modal">Clear</button>
                  </form>
                </div>
            </div><!-- /.modal-content -->
        </div><!-- /.modal-dialog -->
    </div>
    <div id="mapDiv"></div>
      <script type="text/javascript">
        var package_path = window.location.pathname.substring(0, window.location.pathname.lastIndexOf('/'));
        var dojoConfig = {
            //The location.pathname.replace() logic below may look confusing but all its doing is
            // enabling us to load the api from a CDN and load local modules from the correct location.
            packages: [{
    </script>
      <script src="//js.arcgis.com/3.14compact/"></script>
    <!--<script src="//js.arcgis.com/3.13compact"></script>-->
    <script>
        require(["esri/map",
          "esri/dijit/Scalebar",
          "esri/dijit/Geocoder",
          "esri/InfoTemplate",
          "esri/graphic",
          "esri/geometry/Multipoint",
          "esri/symbols/PictureMarkerSymbol",
          "esri/dijit/Popup",
          "dojo/dom",
          "dojo/on",
          "application/bootstrapmap",
          "dojo/domReady!"],
          function (Map, Scalebar, Geocoder, InfoTemplate, Graphic, Multipoint, PictureMarkerSymbol, Popup, dom, on, BootstrapMap) {
            "use strict";
            // Get a reference to the ArcGIS Map class
            var map = BootstrapMap.create("mapDiv", {
              basemap: "streets",
              center:[-122.45, 37.77],
              zoom: 12,
              scrollWheelZoom: false
            var scalebar = new Scalebar({
              map: map,
              scalebarUnit: "dual"
            // Create widget
            var geocoder = new Geocoder({
              value: 'starbucks',
              maxLocations: 10,
              autoComplete: true,
              arcgisGeocoder: true,
              map: map
            },"geosearch");
            geocoder.startup();
            geocoder.on("select", geocodeSelect);
            geocoder.on("findResults", geocodeResults);
            geocoder.on("clear", clearFindGraphics);
            // Geosearch functions
            on(dom.byId("btnGeosearch"),"click", geosearch);
            on(dom.byId("btnClear"),"click", clearFindGraphics);
            map.on("load", function () {
              map.infoWindow.offsetY = 25;
              map.infoWindow.set("highlight", false);
            function geosearch() {
              var def = geocoder.find();
              def.then(function(res){
                geocodeResults(res);
            function geocodeSelect(item) {
              var g = (item.graphic ? item.graphic : item.result.feature);
              g.setSymbol(sym);
              addPlaceGraphic(item.result,g.symbol);
            function geocodeResults(places) {
              places = places.results;
              if (places.length > 0) {
                clearFindGraphics();
                var symbol = sym;
                // Create and add graphics with pop-ups
                for (var i = 0; i < places.length; i++) {
                  addPlaceGraphic(places, symbol);
                zoomToPlaces(places);
              } else {
                alert("Sorry, address or place not found.");
            function addPlaceGraphic(item,symbol)  {
              var place = {};
              var attributes,infoTemplate,pt,graphic;
              pt = item.feature.geometry;
              place.address = item.name;
              place.score = item.feature.attributes.Score;
              // Graphic components
              attributes = { address:place.address, score:place.score, lat:pt.getLatitude().toFixed(2), lon:pt.getLongitude().toFixed(2) };
              infoTemplate = new InfoTemplate("${address}","Latitude: ${lat}<br/>Longitude: ${lon}<br/>Score: ${score}");
              graphic = new Graphic(pt,symbol,attributes,infoTemplate);
              // Add to map
              map.graphics.add(graphic);
            function zoomToPlaces(places) {
              var multiPoint = new Multipoint(map.spatialReference);
                //multiPoint.addPoint(places.location);
                multiPoint.addPoint(places.feature.geometry);
              map.setExtent(multiPoint.getExtent().expand(2.0));
            function clearFindGraphics() {
              map.infoWindow.hide();
              map.graphics.clear();
            function createPictureSymbol(url, xOffset, yOffset, xWidth, yHeight) {
              return new PictureMarkerSymbol(
                  "angle": 0,
                  "xoffset": xOffset, "yoffset": yOffset, "type": "esriPMS",
                  "url": url,
                  "contentType": "image/png",
                  "width":xWidth, "height": yHeight
            var sym = createPictureSymbol("../images/blue-pin.png", 0, 12, 13, 24);
            // Show modal dialog, hide nav
            $(document).ready(function(){
              // Close menu
              $('.nav a').on('click', function(){
                $(".navbar-toggle").click();
              // Geosearch nav menu is selected
              $("#geosearchNav").click(function(e){
                 $("#geosearchModal").modal("show");
              //  // Bootstrap work-around
              $("body").css("margin-right","0px");
                $(".navbar").css("margin-right","0px");
    </script>
    <!-- Bootstrap core JavaScript
    <!-- Placed at the end of the document so the pages load faster -->
    <script src="http://code.jquery.com/jquery-1.11.1.min.js"></script>
    <script src="//maxcdn.bootstrapcdn.com/bootstrap/3.3.2/js/bootstrap.min.js"></script>
  </body>
</html>
abukhan
I found the answers.. Need to add the script tag for  esri javascript after the script tag for the jquery-ui...and then it works
abukhan
