Qt Web View Module not Installed
9132
5
10-12-2015 09:08 AM
deleted-user-AYsXjhkrwuAA
Hi
I have installed AppStudio for ArcGIS on Windows from the beta 4 download (v 10.2.5.1079), and am trying to add a WebView to an app but am receiving the error message at build that;
module "QtWebKit" is not installed
  import QtWebKit 3.0
I had been following the samples from Qt for the QML WebKit Web View.  I also tried with the Qt Web View 1.0 available from 5.5 but this doesn't seem available either.
The what's new indicates that the Web View is available but I'm not sure which we should be using. Can anyone provide some advise and an example that will work with AppStudio for ArcGIS please?
I tried both the windows x64 and x86 versions.
Andrew
I tried again with qt webview 1.0 which does run however I don't see a page in the app.
import QtQuick 2.3
import QtQuick.Controls 1.2
import QtQuick.Layouts 1.1
import QtWebView 1.0
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Controls 1.0
import ArcGIS.AppFramework.Runtime 1.0
App {
    width: 800
    height: 640
               ScrollView {
                width: 1280
                height: 720
                WebView {
                    url: "http://qt-project.org"
Has any body successfully setup a web view with app studio?
AlexanderNohe1
Honored Contributor
I was able to test this out using the Qt Runtime and running it with QML.  I ran into issues with having the scroll view in there.  In order to get this to work in Qt Runtime, I had this:
import QtQuick 2.3
import ArcGIS.Runtime 10.26
ApplicationWindow {
    width: 800
    height: 600
    title: "qtWebKit"
        WebView {
            url:  "http://www.esri.com/"
            anchors.fill: parent
            onLoadProgressChanged: {
                console.log(loadProgress)
AlexanderNohe1
Honored Contributor
Hi Andrew Kesterton​,
I tried using AppStudio as well and was able to get a successful webview set up using:
import QtQuick 2.3
App {
    width: 400
    height: 640
    WebView {
        url:  "http://developers.arcgis.com/qt"
Let me know if you have any issues.
Thanks Alexander.. I think there is maybe something wrong with my install though I have tried uninstalling and re-installing a couple of times. I get these errors when I try to build with your example:
QtWebEngineProcess not found at location C:/Users/andrew/Applications/ArcGIS/AppStudio/bin/bin/QtWebEngineProcess.exe. Trying fallback path...
Installed Qt plugins directory not found at location C:/Users/andrew/Applications/ArcGIS/AppStudio/bin/plugins\qtwebengine. Trying application directory...
Installed Qt WebEngine locales directory not found at location C:/Users/andrew/Applications/ArcGIS/AppStudio/bin/translations\qtwebengine_locales. Trying application directory...
Qt WebEngine locales directory not found at location C:/Users/andrew/Applications/ArcGIS/AppStudio/bin\qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct.
I'm using the 32-bit windows install. As a workaround I'm just opening the link externally which is working fine for now.
Thanks again,
Andrew
AlexanderNohe1
Honored Contributor
Hi Andrew,
It may be possible that my AppStudio install is reading from Qt install as well since QtWebView is packaged as an extra with the Qt installation.
I haven't tried running this on a pure AppStudio machine.
