List ArcGIS Server Services and URLs to Services
7464
6
10-05-2015 11:28 AM
AlexGole
Hi all,
I am trying to list out all the services names and URL and output it to an html table. I am doing so for each of the  folders that we have in our ArcGIS Server. To accomplish that I am using ESRI/request module. I can retrieve the name of the service easy with this module, but can i also retrieve the URL?
ESRI example that I am using:
<!DOCTYPE html>
<html>
<head>
  <title>Get ArcGIS Server Map Service Layer Field Names</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
  <style>
    body{
      font-family: "Arial Unicode MS, Arial, sans-serif";
    #content {
      width: 800px; height: 350px; padding: 5px; overflow: auto;
      border: solid 2px #AAAAAA; background-color: #FFFFFF;
      -moz-border-radius: 5px; -webkit-border-radius: 5px; -o-border-radius: 5px; border-radius: 5px;
      -moz-box-shadow: 0 0 0.5em black; -webkit-box-shadow: 0 0 0.5em black; -o-box-shadow: 0 0 0.5em black; box-shadow: 0 0 0.5em black;
    .failure { color: red; }
    #status { font-size: 12px; }
  </style>
  <script src="http://js.arcgis.com/3.14/"></script>
  <script>
    require(["dojo/dom", "dojo/on", "dojo/dom-class", "dojo/_base/json", "dojo/_base/array", "dojo/string", "esri/request", "dojo/domReady!"], function(dom, on, domClass, dojoJson, array, dojoString, esriRequest) {
        dom.byId("url").value = "http://webgisdevint1/arcgis/rest/services/FRAP";
        dom.byId("content").value = "";
        //handle the Go button's click event
        on(dom.byId("submitRequest"), "click", getContent);
        function getContent(){
          var contentDiv = dom.byId("content");
          contentDiv.value = "";
          domClass.remove(contentDiv, "failure");
          dom.byId("status").innerHTML = "Downloading...";
          //get the url and setup a proxy
          var url = dom.byId("url").value;
          if(url.length === 0){
            alert("Please enter a URL");
            return;
          var requestHandle = esriRequest({
            "url": url,
            "content": {
              "f": "json"
            "callbackParamName": "callback"
          requestHandle.then(requestSucceeded, requestFailed);
        function requestSucceeded(response, io){
          var fieldInfo, pad;
          pad = dojoString.pad;
          //toJson converts the given JavaScript object
          //and its properties and values into simple text
          dojoJson.toJsonIndentStr = "  ";
          console.log("response as text:\n", dojoJson.toJson(response,true));
          dom.byId("status").innerHTML = "";
          //show field names and aliases
          if ( response.hasOwnProperty("services") ) {
            console.log("got some services");
            fieldInfo = array.map(response.services, function(f) {
              return pad("", 0, " ", true) + pad(f.name, 0, " ", true)
            dom.byId("content").value = fieldInfo.join("\n");
          } else {
            dom.byId("content").value = "No field info found. Please double-check the URL.";
        function requestFailed(error, io){
          domClass.add(dom.byId("content"), "failure");
          dom.byId("content").value = dojoJson.toJson(error, true);
  </script>
</head>
<body>
  <p>Enter the URL for a layer in a map service to access metadata about a layer in a map service using esriRequest.</p>
  <p>
    <input type="text" id="url" size="105"/>
    <input id="submitRequest" type="button" value="GO" />
    <span id="status"></span>
  </p>
  <p>
    <h2>Content</h2>
    <p>Check the console for the full response. Here we'll display Field names, aliases and types:</p>
    <textarea id="content"></textarea>
  </p>
</body>
KellyHutchins
Esri Notable Contributor
Would something like this work for your situation where you start with the base url and then add the service name and type?
JS Bin - Collaborative JavaScript Debugging
KellyHutchins
AlexGole
Thant would work great !  That is exactly what I am looking for! Would it be hard to add the end result to a table? I m going to spend my day tomorrow looking for that now. Nicely done kelly! Thanks!
KellyHutchins
Alex,
Yep its fairly easy to display the results in a table. Here's a link to an example that shows the results in a dojo dgrid
AlexGole
Perfect!Thank you so mucj!
MaraKaminowitz
This is a great script.  Is there a way to list out the sub-layers as well?  So instead of
ServiceName     .../MapServer
you get
ServiceNameLayer1     .../MapServer/0
ServiceNameLayer2     .../MapServer/1
etc.
AlexGole
Last question related to this topic. How do I loop through each server's folder? Do I use ESRI/request -- folder.name? I am trying to use a drop down menu populated by each folder. Once selected by user then it fires the event of returning all services names. Thanks, Alex
