Operations Dashboard Install Error
3384
10-01-2015 11:39 AM
MarkMcCart
I am trying to install Operations Dashboard on my machine. I am running Windows 7 64-bit and confirmed that I have .NET 4.5.2 installed. I get the following error in the error log (attached):
ERROR SUMMARY
  Below is a summary of the errors, details of these errors are listed later in the log.
  * Activation of C:\Users\mmccar2\Downloads\OperationsDashboard (3).application resulted in exception. Following failure messages were detected:
  + File, CoherentUI_Host.exe, has a different computed hash than specified in manifest.
ERROR DETAILS
  Following errors were detected during this operation.
  * [10/1/2015 12:04:06 PM] System.Deployment.Application.InvalidDeploymentException (HashValidation)
  - File, CoherentUI_Host.exe, has a different computed hash than specified in manifest.
  - Source: System.Deployment
  - Stack trace:
  at System.Deployment.Application.ComponentVerifier.VerifyFileHash(String filePath, Hash hash)
  at System.Deployment.Application.ComponentVerifier.VerifyFileHash(String filePath, HashCollection hashCollection)
  at System.Deployment.Application.ComponentVerifier.VerifyComponents()
  at System.Deployment.Application.DownloadManager.DownloadDependencies(SubscriptionState subState, AssemblyManifest deployManifest, AssemblyManifest appManifest, Uri sourceUriBase, String targetDirectory, String group, IDownloadNotification notification, DownloadOptions options)
  at System.Deployment.Application.ApplicationActivator.DownloadApplication(SubscriptionState subState, ActivationDescription actDesc, Int64 transactionId, TempDirectory& downloadTemp)
  at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
  at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
  at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
Any suggestions on how to get this installed?
Mark
Tags (1)
MichaelVolz
Esteemed Contributor
You might have firewall security rules that prevented all files from being downloaded.  This is what happened when a few users at my organization tried to download an older 32 bit version of the app.  We had to have IT change a firewall rule to download all necessary files.  I'm not saying this is your problem, but I did encounter this issue with OD.
Have you been able to successfully download previous OD versions?
MichaelVolz
MarkMcCart
This is our first attempt at downloading and using the Operations Dashboard. Thanks for the tip. I'll look into the firewall settings.
MarkMcCart
I've confirmed with our IT folks that the firewall is letting everything through. Attached is the error I get in Fiddler.Ops Dashboard Error.png
