Dear sir...
3278
09-18-2015 12:21 AM
LitanMohanty
Dear sir
the buffer type is overlapping and no of buffer is 13
1.input feature----polygon file
2.output feature class----feature class
3. distances--15, 50 150,300,500,1000,5000,10000,15000,20000,100000,300000
4.Buffer_Unit----meter
5.Field_Name--distance
6.Dissolve_Option---all
7.Outside_Polygons_Only---uncheked
FreddieGibson
Honored Contributor
Could you elaborate more on the question you have? I'm assuming from the information you've provided above that it's related to the Multiple Ring Buffer (Analysis) GP Tool.
LitanMohanty
Dear sir
i suppose to build multiringbuffer on a polygon file of glacier boundary
of himalaya, when i apply on this it gives error having code 999999. when i
apply for a single layer it worked but not all at a time in multiring
buffer tool.
FreddieGibson
Honored Contributor
Could you run the tool, package your result into a gpk and upload it so that I can take a look at it?
DanPatterson_Retired
Please continue this discussion in the parent thread...there are several variants... I will lock this one
parent ...
https://community.esri.com/thread/165626
