Hi everyone,
I've topology maps including whole country.(Count: 4400, format .ecw, summary file size:30GB)
I created mosaic dataset from file geodatabase source. All functions of mosaic dataset could be displayed unproblematic however i didn't create image service.
the process executes so much time (1h 43m) and the system gives error (error:the server’s publishing job didn’t succeed)) when i click on the right button on a mouse to mosaic dataset on Arccatalog
Use Configuration;
ArcGIS Server 10.3.1 (Server A)
Mosaic Dataset (Server B)
Desktop 10.3.1 (Server B)
Mosaic Dataset Source Data (Server C)
(When I create mosaic dataser from one topology map in the sam system configuration topology map can be published add image service and I can display it )
Thanks for your help.
This is not a technical problem, but a matter of licensing. Your data is in *.ecw format. ArcGIS has the ability to view the imagery in the desktop environment, but *.ecw is a proprietary format and we do not have the legal permission to publish images in that format through ArcGIS for Server.
You can purchase a license to publish *.ecw from Hexagon, or you can also convert your imagery into raster tile cache and then publish that cache through ArcGIS for Server. Note that converting to raster tile cache will require disk space, but after completion you could remove the *.ecw files if necessary.
You can learn more from this recording re: creating and publishing cache: Esri Training | Sharing Cached Imagery in ArcGIS
