chart widget not showing dates
3229
09-17-2015 09:49 AM
WarrenMedernach
Hello all,
I'm creating a column chart based on related data and the chart is being generated fine and you can hover over the columns and see the column value. I have tried setting a date field to the Label Field but it is not showing the date.  If I set the Label Field to be one of the
Has anyone else come across this where it won't display a date field?  I have also tested this further and it seems to display a text field fine, but an integer field also failed to display...
Some screen captures to show the setup/config:
Related data fields:
Chart configuration:
And here is a screen cap of the popup:
DanielShaffer2
Hi, Warren!
Did you ever find the solution to this problem? I can't even find any other mention of it on the Community board.
Thanks!
