How to Configure ST_GEOMETRY by Configuring the Oracle extproc to access the geodatabase with SQL?
7120
09-17-2015 11:15 PM
HareshPanchal
Environment:
     Server : Windows Server 2008 R2.
     ArcGIS Server :   ArcGIS Server 10.3 Basic + Oracle 12c Standard (both on same Server)
               I have tried to configure the same but getting error as below.
ORA-28595: Extproc agent : Invalid DLL Path
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 12
ORA-06512: at "SDE.ST_POINT", line 181
28595. 00000 -  "Extproc agent : Invalid DLL Path"
*Cause:    The path of DLL supplied for the extproc execution is invalid.
*Action:   Check if the DLL path is set properly using the EXTPROC_DLLS
           environment variable.
when I tried to execute the SQL: SELECT * FROM USER_LIBRARIES; from Client side, I got the result as following.
ST_SHAPELIBc:\program files\arcgis\desktop10.3\DatabaseSupport\Oracle\Windows64\st_shapelib.dllYVALID0
currently I have configured the extproc.ora file as
C:\Program Files\ArcGIS\Server\DatabaseSupport\Oracle\Windows64\st_shapelib.dll;C:\Program Files\ArcGIS\Server\DatabaseSupport\Oracle\Windows64\libst_raster_ora.dll
George_Thompson
Esri Notable Contributor
Haresh,
The path has a space in it at "Program Files".
If Oracle is on the same machine place the .dll's in the %ORACLE_HOME%\bin folder then update the path on the EXTPROC.ora and SDE user_libraries for the geodatabase.
Configure the Oracle extproc to access the geodatabase with SQL—Help | ArcGIS for Desktop
That should take care of the issue.....
-George
Geodatabase Enterprise GIS
--- George T.
George_Thompson
Haresh,
-George
--- George T.
HareshPanchal
Steps to Configure ST_GEOMETRY by Configuring the Oracle extproc to access the geodatabase with SQL.
Regards,
Pranav M. Pastagia
Torrent Power Ltd., Surat, Gujarat, INDIA.
