Print map with secured WMTS layer using Export Web Map task
4221
09-15-2015 12:50 AM
VishApte
I am trying to print a map that contains secured WMTS layer as basemap and some operational layers. I have read article Printing maps that contain secured services—Documentation (10.3 and 10.3.1) | ArcGIS for Server
However, the above article seems to pertain to printing secured ArcGIS server service. The basemap service I am trying to print is a non-esri secured WMTS service with basic authentication (401 challenge in browser) I am not sure username and password I stored in the Export Web Map Task in a custom toolbox will work for WMTS. I get error below trying to send map JSON.
Executing: ExportWebMap " {"mapOptions":{"showAttribution":true,"extent":{"xmin":16055389.637985548,"ymin":-4594960.104620628,"xmax":16192976.288898917,"ymax":-4503235.670678381,"spatialReference":{"wkid":102100}},"spatialReference":{"wkid":102100},"scale":577790.5542889956}, "operationalLayers":[{"id":"layer0","title":"layer0","opacity":1,"minScale":591658710.9091313,"maxScale":564.2497164995802,"url":"https://somewmtsserver.com/WMTS","type":"wmts","layer":"cfm","style":"default","format":"image/png","tileMatrixSet":"XYZCompatible"},{"id":"mapDiv_graphics","opacity":1,"minScale":0,"maxScale":0,"featureCollection":{"layers":[]}}], "exportOptions":{"outputSize":[800,1100],"dpi":96}}" C:\Users\myname\Documents\ArcGIS\1bbb03a94e3a45e284f49fd83c94ebae.png PNG8 # MAP_ONLY
Start Time: Tue Sep 15 17:23:22 2015
Layer "layer0": Failed to create layer from service at https://somewmtsserver.com/WMTS .
Client tried to access password-protected page without proper authorization.
Failed to execute (ExportWebMap).
Failed at Tue Sep 15 17:23:22 2015 (Elapsed Time: 0.36 seconds)
Has anyone managed to print secured WMTS layer using Export Web Map task? If so, what technique was used?
Vish
TanuHoque
Vish,
Storing credentials with the ExportWebMap Tool should work with non-Esri secured WMTS service too.
Could you pls try this in Desktop and have Fiddler (or some other tool) to check what is going on?
If that does not help much, I'd suggest you to contact Esri Support and open an incident for further investigation.
VishApte
Thanks Tanu for your reply.
I did check using Fiddler and found ArcMap Export Web Map custom task made two identical requests to WMTS service's get capabilities. I expected second request to include "Authorization: Basic xxxxxxx" in header but found it missing. Both calls hade below request
GET https://wmtsserver/WMTS/1.1.2?SERVICE=WMTS&VERSION=1.0.0&REQUEST=GetCapabilities HTTP/1.1
Accept: */*
User-Agent: ArcGIS Client Using WinInet
Host: wmtsserver
Connection: Keep-Alive
Cache-Control: no-cache
I did the same WMTS get capabilities request using browser (IE) and found two requests in fiddler. First one did not have authorization header but second one did after I provided username and password. See second request below.
GET https://wmtsserver/WMTS/1.1.2/?SERVICE=WMTS&VERSION=1.0.0&REQUEST=GetCapabilities HTTP/1.1
Accept: text/html, application/xhtml+xml, */*
Accept-Language: en-AU
User-Agent: Mozilla/5.0 (compatible; MSIE 10.0; Windows NT 6.1; WOW64; Trident/6.0)
Accept-Encoding: gzip, deflate
Host: wmtsserver
Authorization: Basic xxxxxxxxxxxxxxxxxxxx
DNT: 1
So my guess is ArcMap tool is not able to understand 401 challenge to inject basic authorization header in subsequent call even though the tool has the url registered with username and password.
Regards,
Vish
TanuHoque
Thanks Vish.
Which version of ArcGIS Server you are using? Will I be able to access that service to repro that in house? I have a feeling that it got fixed recently...
