Data interoperability connection failes with Oracle spatial relational format
3186
09-14-2015 02:18 AM
RoxanaUrdea
Hi!
I'm trying to add an Interoperability Connection to an Oracle database(Oracle Locator) using Oracle Spatial Relational Format and I get this error:Error connecting to Oracle database: message was `ORA-01017: invalid username/password; logon denied'. (serverType=`ORACLE8', serverName=`instance/database', userName=`user', password=`***', dbname=`')
Otherwise, if I choose Oracle Spatial format, I manage to connect with the same user and password but the data I retreive is incomplete.
Does anyone encountered this problem?There is something that I'm missing?
Thank you!
R
George_Thompson
Esri Notable Contributor
HI Roxana,
Can you provide a little more information for this issue:
-What version of Data Interop is being used? Is ArcGIS Desktop at the same version?
-What version is the Oracle database? Is it a geodatabase (with and SDE schema)?
-Are you using the Oracle full client or Oracle Instant Client?
-Are you able to connect to the Oracle database with SQLPlus or SQLDeveloper?
-Are you able to make a connection in ArcCatalog (outside of the Data Interop extension) and see the expected data?
This will help shed some light on the possible issue.
George
GISGISGIS
--- George T.
