Customize attribute inspector, modifying fields at runtime
3495
09-07-2015 08:30 AM
MarcoRosa
Hi to all ,
i defined a layer info like below ...
         var layerInfoArray = [
            "featureLayer": myfeaturelayer,
            "showAttachments": false,
            "showDeleteButton": false,
            "isEditable": true,
            "fieldInfos": [
                "fieldName": "MyDATE",
                "label": "Date",
                "isEditable": true
                "fieldName": "MyTEXT",
                "label": "Note",
                "isEditable": true,
                "stringFieldOption": AttributeInspector.STRING_FIELD_OPTION_TEXTAREA
and attribute inspector like this ....
          var attributeInspector = new AttributeInspector({
            layerInfos: layerInfoArray
          }, "ui-attributes-container");
All works good , but i would like to change at runtime the behaviour of fields. For example for some conditions i'll like to hide one of the 2 fields or make it not editable.
Is there a way to intercept at runtime the field in the attribute inspector and change it ?
Thank you very much
GP
RowenaTansley1
Can you make fieldInfos a variable and change that as needed, and rebuild the attribute inspector?
