Using Geoprocessing Services into Javascript Application
3901
09-05-2015 10:09 AM
DEVAPP
guys have have create a model builder that have as output a layer with a specific file .lyr so one line have a color and other line have a different color.
I have published this model as GP Services and now i would like to use this GP into Javascript Application.
I would like to develop application that by click on service passing input feature to model and rendering the result of model into app.
There is some code example?
I have seen the Geoprocessing tool linto into popup but doesn't work.
Any help?
ModyBuchbinder
Hi
The lyr definition does not go into the service when you publish.
In Web App Builder you can define the symbology for the output.
In JavaScript you have to write your own code. You can start with this example: https://developers.arcgis.com/javascript/jssamples/gp_resultmapservice.html
DEVAPP
Hi Mody, thanks for your replay.
I have seen this example but the best example for my project is Geoprocessing Tool link into popup.
Now i'm trying to set a geoprocessing tool link into my popup but i have a error:
Uncaught TypeError: Cannot read property 'infoWindow' of undefined
this is my code:
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9">
  <title>Basemaps Widget</title>
  <link rel="shortcut icon" href="https://community.esri.com//esri.github.io/quickstart-map-js/images/favicon.ico">
    <!-- ArcGIS API for JavaScript CSS-->
    <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.10/js/esri/css/esri.css">
    <!-- Web Framework CSS - Bootstrap (getbootstrap.com) and Bootstrap-map-js (github.com/esri/bootstrap-map-js) -->
    <link rel="stylesheet" href="https://community.esri.com//netdna.bootstrapcdn.com/bootstrap/3.1.1/css/bootstrap.min.css" rel="stylesheet">
    <link rel="stylesheet" href="https://community.esri.com//esri.github.io/bootstrap-map-js/src/css/bootstrapmap.css">
  <style>
    html, body, #mapDiv {
      height: 100%;
      width: 100%;
    esriPopup .titlePane, .esriPopup.light .titlePane, .esriPopup.dark .titlePane {
    height: 34px;
    padding: 10px 0px 0px 10px;
    background-color: #938686;
    font-size: 14px;
  </style>
  <!-- ArcGIS API for JavaScript library references -->
    <script src="//js.arcgis.com/3.10compact"></script>
  <script>
    require(["esri/map",
      "dojo/query",
      "esri/dijit/BasemapGallery",
      "esri/dijit/Popup",
        "esri/dijit/PopupTemplate",
        "esri/layers/FeatureLayer",
        "esri/layers/ImageParameters",
        "esri/dijit/InfoWindow",
        "esri/tasks/Geoprocessor",
        "esri/InfoTemplate",
        "dojo/dom-class", "dojo/dom-construct",
      "dojo/on",
      "dojo/dom",
      "dojo/domReady!"],
      function (Map, query, BasemapGallery, Popup, PopupTemplate, FeatureLayer, ImageParameters, InfoWindow, Geoprocessor, InfoTemplate, domClass, domConstruct, on, dom) {
        // Create map
        var map = new Map("mapDiv",{
          basemap: "gray",
          center: [-122.69, 45.52],
          zoom: 3
          //define the info template that is used to display the popup content.
        var template = new InfoTemplate();
        template.setTitle("<b>TITOLO</b>");
        template.setContent("<b>IDENTIFICATIVO: ${NUMERO} <br> DEF: ${DEFINIZIONE}</b>");
        template.highlight = true;
        template.titleInBody = true;
        // Create and add the maps from ArcGIS.com
        var basemapGallery = new BasemapGallery({
          showArcGISBasemaps: true,
          map: map
        }, "basemapGallery");
        basemapGallery.startup();
        // Listen to the basemap selection and set the title
        on(basemapGallery, "onSelectionChange", function() {
          dom.byId("userMessage").innerHTML = basemapGallery.getSelected().title;
        //create a feature layer based on the feature collection
        var featureLayer = new FeatureLayer("http://localhost:6080/arcgis/rest/services/XXX/XXX_XXXI/MapServer/0",
              mode: FeatureLayer.MODE_ONDEMAND,
              outFields: ["*"],
              infoTemplate: template
        map.addLayer(featureLayer);
          //setup the geoprocessing tool that will run when users click the new link. This tool
          //calculates the population in the specified area.
        window.gp = new Geoprocessor("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/GPServ...");
          //create a link that we'll the map's popup window.
          //The link section of the popup has a class called actionList assigned so we can
          //use dojo/query to find the elements with this class name.
        var link = domConstruct.create("a", {
            "class": "action",
            "id": "statsLink",
            "innerHTML": "Population", //text that appears in the popup for the link
            "href": "javascript: void(0);"
        }, query(".actionList", window.map.infoWindow.domNode)[0]);
          //when the link is clicked register a function that will run
        on(link, "click", calculatePopulation);
        // Toggle panel
        on(dom.byId("chevron"), "click", function(e){
          if (query(".glyphicon.glyphicon-chevron-up")[0]) {
            query(".glyphicon").replaceClass("glyphicon-chevron-down","glyphicon-chevron-up");
            query(".panel-body.collapse").removeClass("in");
          } else {
            query(".glyphicon").replaceClass("glyphicon-chevron-up","glyphicon-chevron-down");
            query(".panel-body.collapse").addClass("in");
  </script>
</head>
<body>
  <div class="panel panel-primary panel-fixed">
    <div class="panel-heading">
      <h3 class="panel-title">Basemaps</h3>
        <button id="chevron" class="btn btn-primary btn-xs btn-absolute">
          <span class="glyphicon glyphicon-chevron-down"></span>
        </button>
    </div>
    <div class="panel-body collapse">
      <div id="basemapGallery"></div>
    </div>
  </div>
  <div id="mapDiv"></div>
</body>
</html>
Why i recive this help? Into Require i have set InfoWindow.
Any help?
