Using Composite Address Locators in portal
3447
09-02-2015 11:38 AM
LindseyStone
Has anyone had an issue with using composite address locators in portal.  I created a composite address locator and published it as a geocode service on my arcServer.  Than under utilities added it to my Portal.  When testing it in the map viewer it will pull up my suggestions but will not locate anything.  I tried to link to the service as http and https and same results.  I linked to the same geocode service in ArcGIS Online and it works with no issues.  I tried both of the address locators that the composite locator was made from on my Portal and they work without issue too.
PaulDavidson1
I can't help with the answer (yet) but it would be useful to know what version of Portal you are running?
LindseyStone
I am running Portal and Server 10.3.1
