How can I use a variable that is set in a function on an on event outside of the event?
6534
10
09-02-2015 04:57 AM
MichaelStranovsky
For instance:
featureLayer.on("selection-complete", function (result){
        var pPoly = result.features[0].geometry;
console.log(pPoly);
the console returns undefined
RobertScheitlin__GISP
Michael,
  That when you use lang.hitch to maintain the scope of the function:
Be sure to require dojo/_base/lang
featureLayer.on("selection-complete", lang.hitch(this,function (result){
        //Now to will have access to the external var inside this function
console.log(pPoly);
MichaelStranovsky
Hi Robert,
Thanks for the quick response but I actually want to access the pPoly variable outside the onEvent after the function has been executed.
Michael
TimWitt2
You can define the variable outside your function , but just so you know the console.log will still return undefined since it will run before your selection. To test you would have to put the console.log into your other "on" function.
var pPoly;
console.log(pPoly);
Michael,
  Well think of it the same way now that you have access to the outside scope of the function you just set an outside var that you create to the pPoly.
var pPoly;
console.log(pPoly);
MichaelStranovsky
Yeah I tried that and the console still reports undefined but if I place the console.log inside the event it return correctly. I need to use it though outside the event.
Michael,
   And you are sure you use the code I had in my last post with the lang.hitch and the var outside the function?
MichaelStranovsky
This is what I used:
var pPoly;
console.log(pPoly);
KenBuja
MVP Esteemed Contributor
The question deals more with the progression of the code. Even though the line "console.log" is after the function section, it will get called first. The code inside that function will only occur when that event takes place (i.e. after the selection is complete on the feature layer).
thejuskambi
I think I understand why Micheal is having problem, the console is executed before the event is raised. The selectFeatures method is a deffered method. so you need to you something like this.
var pPoly;
})).then(function(){
     console.log(pPoly);
