Add zoomLevels to the map
4059
6
08-26-2015 05:50 AM
RichardMoussopo
I would like to expand the zoom level up to the layer details. Currently the default zoom level stops at 17. Is it possible to make it go up to 20 for example?
RobertScheitlin__GISP
Richard,
    Here is a sample:
<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Simple Map</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      body {
        background-color: #FFF;
        overflow: hidden;
        font-family: "Trebuchet MS";
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "dojo/domReady!"
      ], function(
        Map
        var lods = [
          "level": 0,
          "resolution": 156543.03392800014,
          "scale": 5.91657527591555E8
          "level": 1,
          "resolution": 78271.51696399994,
          "scale": 2.95828763795777E8
          "level": 2,
          "resolution": 39135.75848200009,
          "scale": 1.47914381897889E8
          "level": 3,
          "resolution": 19567.87924099992,
          "scale": 7.3957190948944E7
          "level": 4,
          "resolution": 9783.93962049996,
          "scale": 3.6978595474472E7
          "level": 5,
          "resolution": 4891.96981024998,
          "scale": 1.8489297737236E7
          "level": 6,
          "resolution": 2445.98490512499,
          "scale": 9244648.868618
          "level": 7,
          "resolution": 1222.992452562495,
          "scale": 4622324.434309
          "level": 8,
          "resolution": 611.4962262813797,
          "scale": 2311162.217155
          "level": 9,
          "resolution": 305.74811314055756,
          "scale": 1155581.108577
          "level": 10,
          "resolution": 152.87405657041106,
          "scale": 577790.554289
          "level": 11,
          "resolution": 76.43702828507324,
          "scale": 288895.277144
          "level": 12,
          "resolution": 38.21851414253662,
          "scale": 144447.638572
          "level": 13,
          "resolution": 19.10925707126831,
          "scale": 72223.819286
          "level": 14,
          "resolution": 9.554628535634155,
          "scale": 36111.909643
          "level": 15,
          "resolution": 4.77731426794937,
          "scale": 18055.954822
          "level": 16,
          "resolution": 2.388657133974685,
          "scale": 9027.977411
          "level": 17,
          "resolution": 1.1943285668550503,
          "scale": 4513.988705
          "level": 18,
          "resolution": 0.5971642835598172,
          "scale": 2256.994353
          "level": 19,
          "resolution": 0.29858214164761665,
          "scale": 1128.497176
          "level": 20,
          "resolution": 0.1492910708238083,
          "scale": 564.248588
          "level": 21,
          "resolution": 0.0746455354119042,
          "scale": 282.124294
        map = new Map("map", {
          basemap: "topo",  //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
          center: [-122.45, 37.75], // longitude, latitude
          zoom: 13,
          lods: lods
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
TimWitt2
Richard,
the zoom level is based on the basemap. I think you would need to use your own basemap to be able to modify the zoom levels, since the ESRI basemaps have their zoom level already set.
Tim
Richard,
   Yes you can add LODs to the map but the selected basemap will not draw at levels that it does not have data for.
LOD | API Reference | ArcGIS API for JavaScript
RichardMoussopo
Thank you Robert
but it looks like LODS only works for ArcGISTiledMapServiceLayer
how would you implement it on the map object?
Richard,
   The map object has a lods option in it's constructor.
Richard,
    Here is a sample:
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #map {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
      body {
        overflow: hidden;
    </style>
    <script>
      var map;
      require([
        "esri/map",
        "dojo/domReady!"
      ], function(
        Map
        var lods = [
          "level": 0,
          "level": 1,
          "level": 2,
          "level": 3,
          "level": 4,
          "level": 5,
          "level": 6,
          "level": 7,
          "level": 8,
          "level": 9,
          "level": 10,
          "level": 11,
          "level": 12,
          "level": 13,
          "level": 14,
          "level": 15,
          "level": 16,
          "level": 17,
          "level": 18,
          "level": 19,
          "level": 20,
          "scale": 564.248588
          "level": 21,
          "scale": 282.124294
          zoom: 13,
          lods: lods
    </script>
  </head>
  <body>
  </body>
</html>
RichardMoussopo
Thank you Robert, it worked as expected!
