Use custom Basemap with BasemapToggle?
6019
7
08-25-2015 04:28 PM
JasonHine
I'm trying to get the BasemapToggle widget to work with a custom Basemap. The widget needs one of the Map.basemap strings, so I'm feeding my custom Basemap to the Map, and then specifying a Map.basemap string in the widget. This kinda works, but the widget thumbnail and title don't change as expected. I get an Uncaught TypeError: Cannot read property 'thumbnailUrl' of undefined, even if I specify the widget's basemaps property. Could this be a bug?  Code is here: JS Bin - Collaborative JavaScript Debugging
Tags (1)
KellyHutchins
Esri Notable Contributor
Not sure if its required but everything seems to work if I add an id to the base map. Here's a revised bit of your code that shows the change I made:
            var myBasemap = new Basemap({
                baseLayers: myBaseLayersCollection,
                title: "My Basemap",
            map = new Map({
                basemap: myBasemap
            view = new MapView({
                container: "viewDiv",
                map: map,
                zoom: 4,
                center: [15, 65]
            // basemap toggle widget
            var toggle = new BasemapToggle({
               map: map,
                basemap: "streets",
                basemaps: {
                    "CustomBasemap": {
                        "title": "My Basemap",
                        "thumbnailUrl": "http://js.arcgis.com/4.0beta1/esri/images/basemap/satellite.jpg"
                    "streets": {
                        "title": "Streets",
                        "thumbnailUrl": "http://js.arcgis.com/4.0beta1/esri/images/basemap/streets.jpg"
            }, "toggleDiv");
KellyHutchins
            map = new Map({
                basemap: myBasemap
                map: map,
                zoom: 4,
                center: [15, 65]
               map: map,
                basemap: "streets",
                basemaps: {
                    "CustomBasemap": {
                    "streets": {
                        "title": "Streets",
            }, "toggleDiv");
JasonHine
That works, thanks Kelly!
KristianEkenes
FYI, the id property on the Basemap will appear in the documentation in the beta2 release.
StephenLead
Honored Contributor
Hi Kelly Hutchins,
How would this work using v3.16 of the API? According to BasemapToggle | API Reference | ArcGIS API for JavaScript​​
NOTE: Basemap objects created using the esri/basemaps class may also be passed as values to this property.
What "value" should be used? I've tried a variety of options at this Edit fiddle - JSFiddle but haven't been able to avoid the "Cannot read property 'thumbnailUrl' of undefined" error.
Steve
StephenLead
Honored Contributor
Derek Swingley wrote a sample at javascript - How to Use Custom Basemaps with BasemapToggle widget? - Geographic Information Systems ... but this is now failing for me using v3.16.
It appears that it's no longer possible to access the esriConfig.defaults.map.basemaps object?
KellyHutchins
Try adding it to esri/basemaps - there's a sample in the api ref showing how this works:
esri/basemaps | API Reference | ArcGIS API for JavaScript
StephenLead
Honored Contributor
perfect - thanks.
