Issue on Updateing ArcGIS API for JS Basemap Using jQuery
2859
08-25-2015 01:15 PM
BruceGreen
Can you please let me know if it is possible to update ArcGIS API Basemap by using jQuery. I am looking for a hack to bind updating of a array to update the basemap option in the map object
Here is what I have tried
<select id="base-map-options">
  <option value="0">Imagery</option>
  <option value="1">Topographic With Lable</option>
</select>
var map;
var basemap = ['topo','streets','imagarey']
require([ "esri/map",
          "esri/layers/ArcGISDynamicMapServiceLayer",
          "dojo/domReady!" ],
         function(Map) { map = new Map("mapDiv", {
                               center: [-126.687482, 54.793577],
                               zoom: 5,
                               basemap: basemap[0]
 $("#base-map-options").on("change", function () {
   basemap[$('option:selected').val()];
as you can see I am trying to update selected index in basemap[] through
but I don't know how to bind this to basemap property of the map object? thanks
