Removing ZM From Geometry Column Polygon Using ArcPy?
7177
6
08-19-2015 11:48 PM
BruceGreen
sing ArcGIS 10.2 for Desktop, I have some Shapefiles which I have no idea why their Geometry column (shape) contain ZM! now I need to remove all those ZM and get a clean polygon instead.
I thought I can use the FeatureClassToShapefile_conversion() but not sure how to disabled both Output has Z Values and Output has M Values through following ArcPy
# Import system modules
import arcpy from arcpy import env
# Set environment settings env.workspace = "C:/data"
# Set local variables
inFeature = ["climate.shp"] outLocation = "C:/output"
arcpy.FeatureClassToShapefile_conversion(inFeatures, outLocation)
Tags (1)
ThomasEmge
Your parameters for arcpy.FeatureClassToFeatureClass are incorrect. Your are providing two parameters but you need at least three. Please take a look at
http://desktop.arcgis.com/en/desktop/latest/tools/conversion-toolbox/feature-class-to-feature-class....
This will work:
import arcpy
env.workspace = "E:\\GIS\\Data"
inFeature = "band-tailed_pigeon.shp"
outFeature = "band-tailed_pigeon-NOZM.shp"
env.outputZFlag = "DISABLED"
env.outputMFlag = "DISABLED"
arcpy.FeatureClassToFeatureClass_conversion(inFeature, env.workspace, outFeature)
or as an alternative you can use arcpy.CopyFeatures_management.
NeilAyres
Your input "climate.shp" is a shapefile not a feature class (a dataset inside a geodatabase).
I would recommend that you actually get all of your data into geodatabases first.
Use arcpy.FeatureClassToFeatureClass_conversion or arcpy.CopyFeatures_management to copy the input to the output and disable Z & M geometries using the flags available in environment settings:
See here :
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
So your code might look like this :
import arcpy
env.workspace = "c:/Data/AGeodatabase.gdb"
inFeature = "climate"
outFeature = "climate2"
env.outputZFlag = "Disabled"
env.outputMFlag = "Disabled"
arcpy.FeatureClassToFeatureClass_conversion(inFeature, outFeature)
BruceGreen
Thanks  Neil but I have every thing in `.shp` and not `gdb` format. In that case how I can set the env workspace?
BruceGreen
I mean In case of having the original file in directory   "C:\\GIS\\ROR" and if I want to save the output in "D:\\Data\\Final\\" Do I have to set two env.workspace for both input and out puts?
BruceGreen
I tried both this methods
import arcpy
outFeature = "E:\\GIS\\Data\\band-tailed_pigeon-NOZM.shp"
import arcpy
but I am getting this error in both case
FeatureClassToFeatureClassC:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy\arcpy\conversion.py1675
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Output Location: Dataset E:\GIS\Data\band-tailed_pigeon-NOZM.shp does not exist or is not supported
ERROR 000735: Output Feature Class: Value is required
Failed to execute (FeatureClassToFeatureClass).
Can you please let me know what I am doing wrong?
RebeccaStrauch__GISP
Re: your code above, the following will work to copy the shape, but not sure if it will do anything for your original question about removing the Z and M.  You can use FeatureClassToShapefile of the FeatureClassToFeatureClass, but I remove the dashes and replaced with _ for the output of the FC2FC version.
import arcpy
theWorkspace = r"D:\Data\Final"
env.workspace = theWorkspace
env.overwriteOutput
inFeature = r"c:\GIS\ROR\"band-tailed_pigeon.shp"
outFeature = "band_tailed_pigeon_NOZM.shp"
#either of the next two will work to copy to new location...
#not sure if it will do anything for you ZM question
#arcpy.FeatureClassToShapefile_conversion(inFeature, theWorkspace)
arcpy.FeatureClassToFeatureClass_conversion(inFeature, theWorkspace, outFeature)
ThomasEmge
This will work:
import arcpy
