insertrow with dictionary and list
8590
15
08-13-2015 02:01 PM
CCWeedcontrol
i have a code that has two issues 1. only one point gets updated with the parcel attributes no other points get updated and 2. the  insertRow i currently have does not work it give me .
line 63, in <module>
    insCursor.insertRow(row)
TypeError: sequence size must match size of the row
basically i am trying to create multiple points that spatially joins the new created points to parcels and updates the points attributes based on what parcel the points are created i am not sure why i am getting the following error.
I have checked to see if the "point" is being updated by the updatecursor with arcpy.FeatureClassToFeatureClass_conversion(point, "C:\Temp\Default.gdb", "p_lyr")  after updateRows.updateRow(updateRow)  and it looks like only one point gets updated.
Separate question, Can i use the SpatialJoin to "In_memory" instead of to a gdb?
I would really appreciate some help please.
working with.
#import modules
import arcpy
# Allow overwrite
arcpy.env.qualifiedFieldNames = False
# Script user input parameters
pointFC = "CCA
parcel = "Parcels1" #Taxparcels
arcpy.env.workspace = r"C:\Temp\Default.gdb"
parcel_lyr = 'parcel_lyr'
sjpoints = "C:\Temp\Default.gdb\sjpoints"
poly = "ACCOUNT_1"
Pnt =  "Account"
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
dfsr = df.spatialReference
fcsr = arcpy.Describe(pointFC).spatialReference
if dfsr.name == fcsr.name:
    """Now do your work"""
point = arcpy.GetParameterAsText(0)  #click
for prow in arcpy.da.SearchCursor(point,'SHAPE@XY'):
        x,y = prow[0]
del prow
point1 = arcpy.Point(x, y)
ptGeometry = arcpy.PointGeometry(point1)
insCursor = arcpy.da.InsertCursor(pointFC,'SHAPE@XY') # create insert cursor
arcpy.MakeFeatureLayer_management(parcel,parcel_lyr)
arcpy.SelectLayerByLocation_management(parcel_lyr,"INTERSECT",point)
#Run the Spatial Join tool, using the defaults for the join operation and join type
arcpy.SpatialJoin_analysis(point, parcel_lyr , sjpoints)
#arcpy.FeatureClassToFeatureClass_conversion(parcel_lyr, "C:\Temp\Default.gdb", "parcel_lyr")
# define the field list from the spatial join
sourceFieldsList = ["TARGET_FID", poly,"SiteAddress",'SiteNum_1', 'SiteStreet_1','SiteStreet_1','SiteNumSfx_1','Predir_1','Postdir_1', 'SiteCity_1', 'SiteZIP_1', 'OwnerName_1']
# define the field list to the original points
updateFieldsList = ["OID@", Pnt,"SiteAddres",'SiteNum','StreetName', 'SiteStreet', 'SiteNumSfx','Predir', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName']
# populate the dictionary from the polygon
valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(sjpoints, sourceFieldsList)}
with arcpy.da.UpdateCursor(point, updateFieldsList) as updateRows:
    for updateRow in updateRows:
        keyValue = updateRow[0]
        if keyValue in valueDict:
            for n in range (1,len(sourceFieldsList)):
                updateRow = valueDict[keyValue][n-1]
            #arcpy.FeatureClassToFeatureClass_conversion(point, "C:\Temp\Default.gdb", "p_lyr")
            with arcpy.da.SearchCursor(point,('Account','SiteAddres','SiteNum','StreetName', 'SiteStreet', 'SiteNumSfx','Predir', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName')) as cursor: # loop through feature set
                for row in cursor:
                    row = []
arcpy.RefreshActiveView()
DanPatterson_Retired
could you format your code please, so that people can refer to line numbers...
Posting Code blocks in the new GeoNet
CCWeedcontrol
For some weird reason it lets me format the code to python when i first posted but noticed that it was just plain text after i posted, i tried to go edit my first post and it seems like it will let me format the text to python but when i hit post it goes back to plan text.
#import modules
import arcpy
# Allow overwrite
pointFC = "CCA
poly = "ACCOUNT_1"
Pnt =  "Account"
        x,y = prow[0]
del prow
                for row in cursor:
                    row = []
edited by Xander Bakker​, formated code
XanderBakker
Esri Esteemed Contributor
Odd... tried to edit the post by the OP, shows formatted code, but once saved it turn normal italic text...
#import modules
import arcpy
# Allow overwrite
pointFC = "CCA
poly = "ACCOUNT_1"
Pnt =  "Account"
        x,y = prow[0]
del prow
                for row in cursor:
                    row = []
so... posted the code here and applied the formatting. I do wonder if lines 18 and 19 are correct? Could you confirm this please?
CCWeedcontrol
I am making sure that i am in the same spatial reference with the following.
XanderBakker
Yes, that's the point, then the code starting from line 20 should be indented...
As Xander Bakker says...your logic is flawed and the code needs to be indented...
>>> if "a" == "b":
...     print("Now do your work")
... else:
...     print("it just carries on anyway")
Now do your work
>>> if "a" == "b":
... else:
not the subtle but oh so important difference in logic
BlakeTerhune
This looks like a problem to me.
    for row in cursor:
        row = []
You're trying to insert an empty row. I think you need the same number of values in the row list as there are fields in the cursor. If you're trying to just insert a blank row, fill the values with nulls (or defaults if nulls not allowed). Maybe something like this?
row = [
    None,  ## Account
    None,  ## SiteAddres
    None,  ## SiteNum
    None,  ## StreetName
    None,  ## SiteStreet
    None,  ## SiteNumSfx
    None,  ## Predir
    None,  ## Postdir
    None,  ## SiteCity
    None,  ## SiteZip
    None  ## OwnerName
PacoAlverez
I have tried the following and both give me errors.
 with arcpy.da.SearchCursor(point,('Account','SiteAddres','SiteNum','StreetName', 'SiteStreet', 'SiteNumSfx','Predir', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName')) as cursor: # 'POINT_X', 'POINT_Y','SHAPE@XY'# loop through feature set
                    for row in cursor:
                        row =[
                            None, #Account
                            None,  #SiteAddres
                            None, #SiteNum
                            None, #StreetName
                            None, #SiteStreet
                            None, #SiteNumSfx
                            None, #Predir
                            None, #Postdir
                            None, #SiteCity
                            None, #SiteZip
                            None,#OwnerName
error
AND
                    for row in cursor:
                         row [0] = row[0] #Account
                         row [1] = row[1] #SiteAddres
                         row [2] = row[2] #SiteNum
                         row [3] = row[3] #StreetName
                         row [4] = row[4] #SiteStreet
                         row [5] = row[5] #SiteNumSfx
                         row [6] = row[6] #Predir
                         row [7] = row[7] #Postdir
                         row [8] = row[8] #SiteCity
                         row [9] = row[9] #SiteZip
                         row [10] = row[10] #OwnerName
error
TypeError: 'tuple' object does not support item assignment
IanMurray
Honored Contributor
You cannot change values with a SearchCursor, only access them.  You would need an UpdateCursor if you were setting values.
