insertrow with dictionary and list
8577
15
08-13-2015 02:01 PM
CCWeedcontrol
i have a code that has two issues 1. only one point gets updated with the parcel attributes no other points get updated and 2. the  insertRow i currently have does not work it give me .
line 63, in <module>
    insCursor.insertRow(row)
TypeError: sequence size must match size of the row
basically i am trying to create multiple points that spatially joins the new created points to parcels and updates the points attributes based on what parcel the points are created i am not sure why i am getting the following error.
I have checked to see if the "point" is being updated by the updatecursor with arcpy.FeatureClassToFeatureClass_conversion(point, "C:\Temp\Default.gdb", "p_lyr")  after updateRows.updateRow(updateRow)  and it looks like only one point gets updated.
Separate question, Can i use the SpatialJoin to "In_memory" instead of to a gdb?
I would really appreciate some help please.
working with.
#import modules
import arcpy
# Allow overwrite
arcpy.env.qualifiedFieldNames = False
# Script user input parameters
pointFC = "CCA
parcel = "Parcels1" #Taxparcels
arcpy.env.workspace = r"C:\Temp\Default.gdb"
parcel_lyr = 'parcel_lyr'
sjpoints = "C:\Temp\Default.gdb\sjpoints"
poly = "ACCOUNT_1"
Pnt =  "Account"
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
dfsr = df.spatialReference
fcsr = arcpy.Describe(pointFC).spatialReference
if dfsr.name == fcsr.name:
    """Now do your work"""
point = arcpy.GetParameterAsText(0)  #click
for prow in arcpy.da.SearchCursor(point,'SHAPE@XY'):
        x,y = prow[0]
del prow
point1 = arcpy.Point(x, y)
ptGeometry = arcpy.PointGeometry(point1)
insCursor = arcpy.da.InsertCursor(pointFC,'SHAPE@XY') # create insert cursor
arcpy.MakeFeatureLayer_management(parcel,parcel_lyr)
arcpy.SelectLayerByLocation_management(parcel_lyr,"INTERSECT",point)
#Run the Spatial Join tool, using the defaults for the join operation and join type
arcpy.SpatialJoin_analysis(point, parcel_lyr , sjpoints)
#arcpy.FeatureClassToFeatureClass_conversion(parcel_lyr, "C:\Temp\Default.gdb", "parcel_lyr")
# define the field list from the spatial join
sourceFieldsList = ["TARGET_FID", poly,"SiteAddress",'SiteNum_1', 'SiteStreet_1','SiteStreet_1','SiteNumSfx_1','Predir_1','Postdir_1', 'SiteCity_1', 'SiteZIP_1', 'OwnerName_1']
# define the field list to the original points
updateFieldsList = ["OID@", Pnt,"SiteAddres",'SiteNum','StreetName', 'SiteStreet', 'SiteNumSfx','Predir', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName']
# populate the dictionary from the polygon
valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(sjpoints, sourceFieldsList)}
with arcpy.da.UpdateCursor(point, updateFieldsList) as updateRows:
    for updateRow in updateRows:
        keyValue = updateRow[0]
        if keyValue in valueDict:
            for n in range (1,len(sourceFieldsList)):
                updateRow = valueDict[keyValue][n-1]
            #arcpy.FeatureClassToFeatureClass_conversion(point, "C:\Temp\Default.gdb", "p_lyr")
            with arcpy.da.SearchCursor(point,('Account','SiteAddres','SiteNum','StreetName', 'SiteStreet', 'SiteNumSfx','Predir', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName')) as cursor: # loop through feature set
                for row in cursor:
                    row = []
arcpy.RefreshActiveView()
BlakeTerhune
Looking at this again, I'm not sure I'm on the right track. I see you've got a couple cursors open and I can't follow what the goal is. Could you please clarify (maybe with a screenshot) what exactly you're trying to do here?
PacoAlverez
ok,  i would like to create points to a point layer by mouse click . Some times i will only create one point and some times 5,10, etc. I need the points to update certain attributes from the parcels they are created on top of at that time.
thanks for the reply.
BlakeTerhune
This sounds like something that has been discussed many other times (three by you in the past month). Is this thread for 2CDSD 2C​ or Paco ALVAREZ​?
PacoAlverez
I am paco
BlakeTerhune
And I am done here.
CCWeedcontrol
I have tried to edit my original and my second post  with firefox, explorer and Chrome and they all do the same thing. When i select the python text and click on insert syntax highlighting then select python it puts the code in python format but once i hit save reply it shows my post but it's back to plan text. WTH is going on?
