Nliu's TOC Widget, zoom and layer error
3923
5
08-10-2015 11:54 AM
AshleyPeters
I'm still new to the JavaScript API, so please bear with me.
I am having a similar issue as to what Dominik mentions here: Problems with TOC or map
I do not have the Editor or Measurement dijit added in. Right now, I am missing several layers in the TOC. When using the developer tools in Firefox, I get an error that the graphic can not be drawn. They happen to all be point layers, but other point layers are pulling in without throwing that error.
Also, when I zoom on the map, the map is not updating unless I pan. When I pan, the polygons are not drawing. If I do not pan, the resolution never gets any better.
Any ideas?
Thanks in advance!
Ashley
AshleyPeters
I managed to solve the problem. I rewrote my code to follow this example: Add two dynamic maps | ArcGIS API for JavaScript. It fixed the zoom issue. I had overlooked an issue where I declared some of the layers ("MapServer" was missing at the end). Fixed that as well. Now all things are working as expected.
KenBuja
MVP Esteemed Contributor
Can you post your code or show how it's not operating correctly using a site like JSFiddle or JSBin?
AshleyPeters
I don't currently have JSFiddle or JSBin downloaded, but I'll see if I can get one of them onto my computer. Here's the portion of my .js file dealing with the TOC dijit:
//Declare Base Layers to map
var boundaries = new ArcGISDynamicMapServiceLayer("https://MyURL/rest/services/Basemap/MapServer");
//Declare State Parks layers
var stateparksL = new FeatureLayer("https://MyURL/rest/services/SP_DCNR/MapServer/1");
var stateparksentL = new FeatureLayer("https://MyURL/rest/services/SP_DCNR/MapServer/0");
//Declare Hunting layers
var WMA = new FeatureLayer("https://MyURL/rest/services/Hunting_DCNR/MapServer/2");
var ranges = new FeatureLayer("https://MyURL/rest/services/Hunting_DCNR/MapServer/1");
var checkStations = new FeatureLayer("https://MyURL/rest/services/Hunting_DCNR/MapServer/0");
//Declare FW layers
var SLDtracts = new FeatureLayer("https://MyURL/rest/services/FW_DCNR/MapServer/13");
var FWtracts = new FeatureLayer("https://MyURL/rest/services/FW_DCNR/MapServer/12");
var BartramPOI = new FeatureLayer("https://MyURL/rest/services/FW_DCNR/MapServer/11");
var BartramRoutes = new FeatureLayer("https://MyURL/rest/services/FW_DCNR/MapServer/10");
var BartramTrail = new FeatureLayer("https://MyURL/rest/services/FW_DCNR/MapServer/9");
var FWtrails = new FeatureLayer("https://MyURL/rest/services/FW_DCNR/MapServer/8");
var FWaccess = new FeatureLayer("https://MyURL/rest/services/FW_DCNR/MapServer/7");
var FWactivities = new ArcGISDynamicMapServiceLayer("https://MyURL/rest/services/FW_DCNR/MapServer");
                FWactivities.setVisibleLayers([1,2,3,4,5,6]);
//Declare Fishing layers
var publicLakes = new FeatureLayer("https://MyURL/rest/services/Fishing_DCNR/MapServer/6");
var boatRamps = new FeatureLayer("https://MyURL/rest/services/Fishing_DCNR/MapServer/5");
var navAids = new FeatureLayer("https://MyURL/rest/services/Fishing_DCNR/MapServer/4");
var offshoreReefs = new FeatureLayer("https://MyURL/rest/services/Fishing_DCNR/MapServer/3");
var nearshoreReefs = new FeatureLayer("https://MyURL/rest/services/Fishing_DCNR/MapServer/2");
var inshoreReefs = new FeatureLayer("https://MyURL/rest/services/Fishing_DCNR/MapServer/1");
//Declare Districts
var WFFDistricts = new FeatureLayer("https://MyURL/rest/services/Districts_WGS84/0");
//Declare Offices and Facilities
var hatcheries = new FeatureLayer("https://MyURL/rest/services/OfficesFacilities_WGS84/6");
var SLDFacilities = new FeatureLayer("https://MyURL/rest/services/OfficesFacilities_WGS84/5");
var Facilities = new FeatureLayer("https://MyURL/rest/services/OfficesFacilities_WGS84/4");
var WFFDistOff = new FeatureLayer("https://MyURL/rest/services/OfficesFacilities_WGS84/3");
var MRDOffices = new FeatureLayer("https://MyURL/rest/services/OfficesFacilities_WGS84/2");
var Offices = new FeatureLayer("https://MyURL/rest/services/OfficesFacilities_WGS84/1");
var DCNRHQ = new FeatureLayer("https://MyURL/rest/services/OfficesFacilities_WGS84/0");
//Add all declared layers to map
  1. mapMain.addLayers([boundaries, stateparksL, WMA, ranges,
    checkStations, SLDtracts, FWtracts, BartramPOI, BartramRoutes, BartramTrail,
    FWtrails, FWaccess, FWactivities, publicLakes, boatRamps, navAids,
    offshoreReefs, nearshoreReefs, inshoreReefs, WFFDistricts, hatcheries,
    SLDFacilities, Facilities, WFFDistOff, MRDOffices, Offices, DCNRHQ]);
//Add TOC widget once all layers have been added to the map
  1. mapMain.on('layers-add-result', function(evt){
overwrite the default visibility of service.
                // TOC
will honor the overwritten value.
//dynaLayer1.setVisibleLayers([2, 5, 8, 11]);
                //try
                  toc
= new TOC({
map: mapMain,
layerInfos: [{
layer: DCNRHQ,
title: 'DCNR Headquarters'
        layer: Offices,
title: 'Offices'
layer: MRDOffices,
title: 'Marine Resources Division Offices'
        layer: WFFDistOff,
        title: 'Wildlife and Freshwater Fisheries
District Offices'
        layer: Facilities,
        title: 'Facilities'
        layer: SLDFacilities,
        title: 'State Lands Facilities'
        layer: hatcheries,
        title: 'Hatcheries'
        layer: WFFDistricts,
Districts'
        layer: inshoreReefs,
title: 'Inshore Artificial Reefs'
layer: nearshoreReefs,
title: 'Nearshore Artificial Reefs'
        layer: offshoreReefs,
        title: 'Offshore Artificial Reefs'
        layer: navAids,
        title: 'Navigational Aids'
        layer: boatRamps,
        title: 'DCNR-managed Boat Ramps'
        layer: publicLakes,
        title: 'DCNR-owned Public Fishing Lakes'
        layer: FWactivities,
title: 'Activities'
layer: FWaccess,
                      title: 'Parking and Access'
        layer: FWtrails,
        title: 'Trails'
        layer: BartramTrail,
        title: 'Bartram Canoe Trail'
        layer: BartramRoutes,
        title: 'Routes'
        layer: BartramPOI,
        title: 'Points of Interest'
layer: FWtracts,
title: 'Forever Wild Tracts'
        layer: SLDtracts,
        title: 'State Lands Division Recreational
Tracts'
        layer: checkStations,
        title: 'Checking Stations'
        layer: ranges,
        title: 'Ranges'
        layer: WMA,
        title: 'Wildlife Management Areas'
        layer: stateparksentL,
        title: 'State Parks Entrances'
        layer: stateparksL,
        title: 'State Parks'
        layer: boundaries,
title: 'States and Counties',
noLegend: true
//collapsed: false, // whether this root layer should be collapsed
initially, default false.
//slider: false // whether to display a transparency slider.
'tocDiv');
toc.startup();
KenBuja
JSFiddle/JSBin are simply websites you can put your code to show it in action, like this. Putting a subset of your code on one of these sites can help you pinpoint a problem, especially if you can replicate the issue.
AshleyPeters
And I am getting this error, presumably for the layers it isn't drawing:
"dojo.io.script error"
  • [object Error] {
      code
    : 400,
      description
      details
      httpCode
    : 400,
      log
    : undefined,
      message
    : "Invalid URL",
      number
    : 0}
AshleyPeters
