Help - Exporting Multiple Map Documents to PDF using Python
6967
13
08-06-2015 08:06 AM
anayoung
I am new to coding. I am trying to write a script that will allow me to export multiple map documents to PDF using Python. I found some code to do just that at the following ESRI help link 44242 - Export map documents to PDF using Python . However when I try to run it I get the below Runtime Error message. The only thing I changed from the original code was the workspace pathway. Thank you very much, Ana
>>> import arcpy, os
... arcpy.env.workspace = ws = "C:\Users\00177153\Desktop\ArcPy"
... mxd_list = arcpy.ListFiles("*.mxd")
... for mxd in mxd_files:
...     current_mxd = arcpy.mapping.MapDocument(os.path.join(ws, mxd))
...     pdf_name = mxd[:-4] + ".pdf"
...     arcpy.mapping.ExportToPDF(current_mxd, pdf_name)
... del mxd_files
Runtime Error
     File "<string>", line 7, in <module>
NameError: name 'mxd_files' is not defined
WesMiller
I tested this code, try this
import arcpy, os
arcpy.env.workspace = ws = r"C:\Users\00177153\Desktop\ArcPy"
for mxd in mxd_list:
    pdf_name = os.path.join(ws,mxd[:-4]) + ".pdf"
    print pdf_name
WesMiller
Try changing "mxd_files" to "mxd_list"
anayoung
I tried that but reieved the following error message:
Runtime error
TypeError: 'NoneType' object is not iterable
IanMurray
Honored Contributor
That would mean that there are no map documents in the filepath you gave.
Also:
Should just be:
arcpy.env.workspace = "C:\Users\00177153\Desktop\ArcPy"
However, if there are no mxds in that directory, then you will have no items in your list to export, hence the error.
WesMiller
Ian Murray​he is using ws on line 9 for readability he should do
arcpy.env.workspace = r"C:\Users\00177153\Desktop\ArcPy"
IanMurray
Honored Contributor
yea missed that
WesMiller
Me too i didn't see it till i reconfigured the code
WesMiller
import arcpy, os
    print pdf_name
anayoung
With much appreciation for you - I got it!
See below code that worked (i.e. inserted 'r' and changed mxd_files to mxd_list).
The original code on the ESRI help link should be adjusted. When I tried 'print pdf_name' I got an empty 'test1.pdf'.
>>> import arcpy, os
... arcpy.env.workspace = ws = r"C:\Users\00177153\Desktop\ArcPy"
... for mxd in mxd_list:
... del mxd_list
My next challenge will be to export the PDFs to another location than the MXDs. I will put in another question for that. Thank you very much.
WesMiller
See the adjusted code below
>>> import arcpy, os
... pdfws = r"some\other\path
...     pdf_name = os.path.join(pdfws,mxd[:-4]) + ".pdf"
... del mxd_list
