Help - Exporting Multiple Map Documents to PDF using Python
6999
13
08-06-2015 08:06 AM
anayoung
I am new to coding. I am trying to write a script that will allow me to export multiple map documents to PDF using Python. I found some code to do just that at the following ESRI help link 44242 - Export map documents to PDF using Python . However when I try to run it I get the below Runtime Error message. The only thing I changed from the original code was the workspace pathway. Thank you very much, Ana
>>> import arcpy, os
... arcpy.env.workspace = ws = "C:\Users\00177153\Desktop\ArcPy"
... mxd_list = arcpy.ListFiles("*.mxd")
... for mxd in mxd_files:
...     current_mxd = arcpy.mapping.MapDocument(os.path.join(ws, mxd))
...     pdf_name = mxd[:-4] + ".pdf"
...     arcpy.mapping.ExportToPDF(current_mxd, pdf_name)
... del mxd_files
Runtime Error
     File "<string>", line 7, in <module>
NameError: name 'mxd_files' is not defined
anayoung
Thank you, Wes.
That worked very well except that I had to leave off the "del mxd_list" this time. Doing that the code created another empty "test1" PDF along with the other ones I wanted. Any thoughts as to why leaving off the "del mxd_list" and the empty "test1" PDF happened?
WesMiller
Not sure unless you ran it one time and it failed, then the "test1" may have been still in the list. I would try closing python completely down then reopening and adding back the "del mxd_list" to see if it clears it up you may also want ti delete the already created set or add to the top of your code under the imports
anayoung
Okay - it worked after I closed it down a few times and added the 'del mxd_list' back in.
Whew! Thanks again, Wes.
anayoung
Thanks, Rebecca. That worked out well. Your help was much appreciated by this beginner.
