Adding marker in arcgis online webapp
4388
08-05-2015 04:37 AM
sujeetyadav
I am able to add marker symbol in arcgis online web map but when i add marker symbol in arcgis online webapp it is not showing the marker on the map
Adding marker in web map link http://www.arcgis.com/home/webmap/viewer.html?marker=-123.065320;44.882852;;Race start and finish;;Grindstone 100 Ultra Marathon&level=7
this link works fine but when i add marker in webapp as below
http://www.arcgis.com/apps/Viewer/index.html?appid=daf7d40ac8a44a83a760995aecb1f446&marker=-123.0653...
it did not display the marker
Plz help
Tags (1)
by Anonymous User
Not applicable
I, too, would like to know the answer to this question. Have you found a solution?
by Anonymous User
Not applicable
the only solution I've found so far is to create a point feature class and publish it to AGO - then you can add it to your web map like any other layer
this isn't a great solution for a web map, tho, since the points would be static  - you'd lose scalability in the web map unless you created a ton of points and gave them all different scale dependencies. Of course, that also depends on the scale of your other features as well as how many there are, etc.
