Unable to edit in ArcGIS 10.3.1 using SOAP API
4041
08-03-2015 03:43 AM
mohmmadfarooq
I am not able to edit using SOAP API in ArcGIS server 10.3.1 while I am able to edit in the earlier versions of the ArcGIS. The server is giving error "Error processing server request". The editing is failing for both SQL and Oracle database.
JonathanQuinn
Esri Notable Contributor
Can you edit at REST?  You can add the feature service to ArcGIS Online as a quick test.  Do the Server logs show any errors other than the error processing server request message?
MohmmadBhat
Rest editing is working properly. Even I am able to delete the features using SOAP API.
I am not able to add feature and edit attributes of the feature using SOAP.
SOAP Request: Add feature
<?xml version="1.0"
encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Body><Add
xmlns="http://www.esri.com/schemas/ArcGIS/10.3"><LayerOrTableID
xmlns="">0</LayerOrTableID><DataObjects
xmlns=""><DataObjectArray><DataObject
xmlns:q1="http://www.esri.com/schemas/ArcGIS/10.3"
xsi:type="q1:GraphicFeature"><Properties><PropertyArray
/></Properties><Geometry
xsi:type="q1:PointN"><X>537804.03974440356</X><Y>4817959.3768005269</Y></Geo
metry></DataObject></DataObjectArray></DataObjects><GdbVersion
xmlns=""
/><RollbackOnFailure
xmlns="">true</RollbackOnFailure></Add></soap:Body></soap:Envelope>
I have attached the AGS log file for ADD and EDIT request for SOAP and Add request for REST.
KhurramShahzad
I have similar issue, do we have any resolution to this problem?
KhurramShahzad
Farooq helped me to solve this issue. I just had to add TimeReference property. Here is the code:
dObjects.TimeReference = new TimeReference();
