esri/views/SceneView module breaks Object.assign()
3595
07-23-2015 04:39 AM
MatejVrtich
There is Object.assign() polyfill coming with esri/views/SceneView module (inside the esri/views/3d/canvas3d/webgl-engine/lib/es6-shim submodule).
This polyfill seems to be wrong.
According the https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Object/assign, the Object.assign() should be able to process multiple sources, which the Object.assign() polyfill coming with esri/views/SceneView does not support.
Example:
Object.assign({}, {a:1}, {b:2}); // should return {a:1, b:2}, the polyfill returns {a:1}.
You can try the example alive:
1. Open http://developers.arcgis.com/javascript/beta/sample-code/source-code/3d/basic3d/index.html in Chrome (Chrome does not implement the Object.assign() yet, so the polyfill will be used)
2. Run Object.assign({}, {a:1}, {b:2}); in the console
3. The result is {a:1}
4. Open http://developers.arcgis.com/javascript/beta/sample-code/source-code/3d/basic3d/index.html in Firefox (Firefox already implements Object.assign() since v34)
5. Run Object.assign({}, {a:1}, {b:2}); in console
6. The result is {a:1, b:2}
Generally I do not think it is good idea to pollute global scope with polyfills coming with EsriJS library itself.
Tags (1)
YannCabon
Hi Matej,
we will work on this for beta2.
YannCabon
Hi Matej,
