context menu
9042
16
07-20-2015 08:22 PM
LefterisKoumis
I need to create a right click context menu for one of my graphics. I am using the example found at:
Display context menu | ArcGIS API for JavaScript
as an example.
In the code I am already using the GraphicsLayer.on("mouse-over", function(evt)) to set the infowindow for other graphics (not for the one that I need to set the context menu).
Can the GraphicsLayer listen to multiple triggers? Or do they need to be combined under a single instance of GL.on?
Thanks.
RobertScheitlin__GISP
Lefteris,
  OK, Here is your sample code corrected:
<!DOCTYPE HTML>
<html>
<head>
  <title>My Map</title>
  <link rel="stylesheet" href= "http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
  <style>
    html,
    body,
    html, body, #map {
      height:100%;
      margin: 0;
      padding: 0;
      width:100%;
      overflow:hidden;
  </style>
  <script src="http://js.arcgis.com/3.14/"></script>
  <script>
    var myMap, ctxMenuForGraphics;
    require([
      "esri/map",
      "esri/geometry/Point",
      "esri/symbols/SimpleMarkerSymbol",
      "esri/symbols/SimpleLineSymbol",
      "esri/graphic",
      "esri/layers/GraphicsLayer",
      "esri/geometry/Polyline",
      "esri/SpatialReference",
      "dojo/dom",
      "dojo/on",
      "dijit/Menu",
      "dijit/MenuItem",
      "dojo/domReady!"
  ], function (
      Map,
      Point,
      SimpleMarkerSymbol,
      SimpleLineSymbol,
      Graphic,
      GraphicsLayer,
      Polyline,
      SpatialReference,
      dom,
      on,
      Menu,
      MenuItem
      myMap = new Map("map", {
        basemap: "streets",
        center: [-122.16, 37.7238],
        zoom: 15,
        SpatialReference: 102100
      myMap.on("load", init);
      function init() {
        var point1 = new Point(-122.159, 37.724, myMap.SpatialReference);
        var point2 = new Point(-122.169, 37.721, myMap.SpatialReference);
        var line = new Polyline(myMap.SpatialReference);
        var gL = new GraphicsLayer();
        line.addPath([point1, point2]);
        var lineSymbol = new SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0, 0.5]), 4);
        var pointSymbol = new SimpleMarkerSymbol().setColor(new dojo.Color([255, 0, 0, 0.5]));
        myGraphicMarker = new Graphic(point1, pointSymbol,{ "name": "Begin"});
        myGraphicMarker2 = new Graphic(point2, pointSymbol, {"name": "End"});
        gra = new Graphic(line, lineSymbol, {"name": "Project"});
        ctxMenuForGraphics = new Menu({});
        ctxMenuForGraphics.addChild(new MenuItem({
          label: "Test",
          onClick: function () {
            alert("Testing menu");
          label: "Test 2",
            alert("Testing menu 2");
        ctxMenuForGraphics.startup();
        gL.add(myGraphicMarker);
        gL.add(myGraphicMarker2);
        gL.add(gra);
        myMap.addLayer(gL);
        on(gL, 'mouse-over', function (evt) {
          if (evt.graphic.attributes.name === "Project") {
            ctxMenuForGraphics.bindDomNode(evt.graphic.getDojoShape().getNode());
        on(gL, 'mouse-out', function (evt) {
            ctxMenuForGraphics.unBindDomNode(evt.graphic.getDojoShape().getNode());
  </script>
</head>
<body class="claro" style="font-size: 0.75em;">
  <div id="map" class="map"></div>
</body>
</html>
TimWitt2
Lefteris,
GraphicsLayer can listen to a multitude of events. Just look under Events here: GraphicsLayer | API Reference | ArcGIS API for JavaScript
Just use GraphicsLayer.on("mouse-over", function(evt))
Once that function is over you can have another GraphicsLayer.on("click", function(evt))
In your case, you can still add the code you need for the right-click context on top of the infowindow.
Tim
LefterisKoumis
Thank you Tim.
I think I need to be more specific. What if you have two identical calls, GraphicsLayer.on("mouse-over", function(evt))
As I mentioned, I already have one for the infotemplate and then I need another one for the context menu as described by the ESRI's example as stated in my previous post. The problem is that both calls are intended for different graphics.
Perhaps, I could use only one call, and based on the graphics id the appropriate action is taken.
TimWitt2
You could always create two different GraphicsLayers. You are not restricted to just one GraphicsLayer. Create one graphicslayer that has the mouse-over for an infotemplate and then another for your context menu.
GraphicsLayer1.on("mouse-over", function(evt){
     infotemplate code
GraphicsLayer2.on("mouse-over", function(evt){
     right-click code
LefterisKoumis
Thanks Tim. I am aware of it. But I am using the same graphics layer for my graphics for other reasons.
Why not just add the new code you want to execute to the same event handler you already have in place?
So you just evaluate the graphic to see if it is the one you want to work with or not.
TimWitt2
Robert,
you are right, the only thing the code does in the example is, identify which graphic you are hovering over and where the geometry is located. Both those things can run independent from the infowindow.
Tim
LefterisKoumis
Thanks Robert. That's what I was thinking as I mentioned on my response to Tim.
LefterisKoumis
This is a part of the code....
I first call the createGraphicsMenu, as listed on:
except the   myGraphicsLayer2.on("mouse-over",function (event), to create the context menu.
because I incorporated in the existing call.
So, if the graphics is Begin or End, the infowindow are displayed.
If I right click on the Project graphic, the map "jerks" (pans for half inch) and there is no display of context menu
What am I doing wrong?
Thank you.
createGraphicsMenu();
  myGraphicsLayer2.on("mouse-over",function (event) {
                map.graphics.clear();  //use the maps graphics layer as the highlight layer
                var graphic = event.graphic;
  if (graphic.attributes.name === "Begin"){
                map.infoWindow.setContent(myGraphicMarker.getContent());
                map.infoWindow.setTitle(myGraphicMarker.getTitle());
                var highlightGraphic = new Graphic(myGraphicMarker.geometry, pointSymbol);
                map.graphics.add(highlightGraphic);
                map.infoWindow.show(event.screenPoint,
                  map.getInfoWindowAnchor(event.screenPoint));
  if (graphic.attributes.name === "End"){
                map.infoWindow.setContent(myGraphicMarker2.getContent());
                map.infoWindow.setTitle(myGraphicMarker2.getTitle());
                var highlightGraphic = new Graphic(myGraphicMarker2.geometry, pointSymbol);
  if (graphic.attributes.name === "Project"){
       ctxMenuForGraphics.bindDomNode(graphic.getDojoShape().getNode());
  map.infoWindow.resize(120, 70);
  map.graphics.on("mouse-out", function () {
                map.infoWindow.hide();
  ctxMenuForGraphics.unBindDomNode(graphic.getDojoShape().getNode());
Lefteris,
   Why not create the context menu on the graphic when the graphic is created (just the ones with the "Project" attribute) instead of trying to add it and remove it every time someone hover over and out?
