If-then statement in field calculator
6800
5
07-20-2015 02:13 PM
by Anonymous User
Not applicable
I am new to scripting and am trying to figure out how to write an If-then statement to populate a field in field calculator.  I want to basically say if a certain field has a NULL value in it, then the result is "No" in that field.  If the certain field has a value in it, then I want the result to be "Yes".
by Anonymous User
Not applicable
Thank you everyone for your help!  I was able to accomplish what I wanted by doing a selection query and field calculating on the results.
JoeBorgione
Not sure it's possible; my work around has always been to create a selection and calc your value.
select:  'TheField' is null
IanMurray
Honored Contributor
It would be something like this.
Expression:
Reclass(!FieldwithNullValuesHere!)
Expression Type:
Python_9.3
Code Block:
def Reclass(field):
  if field == "None":
    return "No"
  else:
    return "Yes"
DarrenWiens2
This is assuming your field is actually <Null>, not blank, or something else:
Codeblock:
def blah(field):
  if field:
    return "Yes"
  else:
    return "No"
expression:
blah(!yourfield!)
FreddieGibson
Honored Contributor
See the following Esri Documentation and look for the section titled "Using Code Blocks"
Calculate Field Examples
http://desktop.arcgis.com/en/desktop/latest/manage-data/tables/calculate-field-examples.htm
by Anonymous User
Not applicable
