Rendering
5127
8
07-20-2015 02:41 AM
SatyanarayanaNarmala
Hi
i am using this example exactly to show renedering based on values.
https://developers.arcgis.com/javascript/jssamples/renderer_generate_renderer.html
app.fields = {
          "sde.sde.CONST_WISE_HOUSING.total_bens": "Total Beneficiaries", "sde.sde.CONST_WISE_HOUSING.sc": "SC Beneficiaries", "sde.sde.CONST_WISE_HOUSING.st": "ST Beneficiaries",
          "sde.sde.CONST_WISE_HOUSING.bc": "BC Beneficiaries", "sde.sde.CONST_WISE_HOUSING.others": "Others Beneficiaries" , "sde.sde.CONST_WISE_HOUSING.bbl": "Below Basement Level Stage", "sde.sde.CONST_WISE_HOUSING.bl": "Basement Level Stage",
          "sde.sde.CONST_WISE_HOUSING.ll": "Lentel Level Stage", "sde.sde.CONST_WISE_HOUSING.rl": "Roof Level Stage", "sde.sde.CONST_WISE_HOUSING.completion":"Completed Stage"
app.outFields = ["sde.sde.CONST_WISE_HOUSING.total_bens", "sde.sde.CONST_WISE_HOUSING.sc", "sde.sde.CONST_WISE_HOUSING.st", "sde.sde.CONST_WISE_HOUSING.bc", "sde.sde.CONST_WISE_HOUSING.others", "sde.sde.CONST_WISE_HOUSING.bbl", "sde.sde.CONST_WISE_HOUSING.bl", "sde.sde.CONST_WISE_HOUSING.ll", "sde.sde.CONST_WISE_HOUSING.rl", "sde.sde.CONST_WISE_HOUSING.completion", "sde.sde.AP_Const.asmbname"];
When i add "sde.sde.AP_Const.asmbname"  to out fields, drop down not working, showing an error with filtering Select
where am i going wrong
these are the fields
    sde.sde.AP_Const.objectid ( type: esriFieldTypeOID , alias: objectid )
    sde.sde.AP_Const.dname ( type: esriFieldTypeString , alias: dname , length: 30 )
    sde.sde.AP_Const.asmbname ( type: esriFieldTypeString , alias: asmbname , length: 30 )
    sde.sde.AP_Const.cons_id ( type: esriFieldTypeSmallInteger , alias: cons_id )
    sde.sde.AP_Const.shape ( type: esriFieldTypeGeometry , alias: shape )
    sde.sde.AP_Const.st_area(shape) ( type: esriFieldTypeDouble , alias: st_area(shape) )
    sde.sde.AP_Const.st_length(shape) ( type: esriFieldTypeDouble , alias: st_length(shape) )
    sde.sde.CONST_WISE_HOUSING.objectid ( type: esriFieldTypeInteger , alias: objectid )
    sde.sde.CONST_WISE_HOUSING.constcode ( type: esriFieldTypeInteger , alias: constcode )
    sde.sde.CONST_WISE_HOUSING.total_bens ( type: esriFieldTypeInteger , alias: Total_bens )
    sde.sde.CONST_WISE_HOUSING.sc ( type: esriFieldTypeInteger , alias: SC )
    sde.sde.CONST_WISE_HOUSING.st ( type: esriFieldTypeInteger , alias: ST )
    sde.sde.CONST_WISE_HOUSING.bc ( type: esriFieldTypeInteger , alias: BC )
    sde.sde.CONST_WISE_HOUSING.others ( type: esriFieldTypeInteger , alias: others )
    sde.sde.CONST_WISE_HOUSING.bbl ( type: esriFieldTypeInteger , alias: BBL )
    sde.sde.CONST_WISE_HOUSING.bl ( type: esriFieldTypeInteger , alias: BL )
    sde.sde.CONST_WISE_HOUSING.ll ( type: esriFieldTypeInteger , alias: LL )
    sde.sde.CONST_WISE_HOUSING.rl ( type: esriFieldTypeInteger , alias: RL )
    sde.sde.CONST_WISE_HOUSING.completion ( type: esriFieldTypeInteger , alias: Completion )
    sde.sde.AP_Const.state ( type: esriFieldTypeString , alias: sde.sde.AP_Const.state , length: 20 )
thejuskambi
Satya,
Sorry, I was just trying to explain why your FilteringSelect was not working. I shall try to explain a bit more.
Even though the app.outFields contains the STATE_NAME and NAME it is not adding them to the dropdown item source by excluding them since they are not part of the app.Fields. probably instead of telling you to add it to app.Fields I should have said to exculde your name field from while populating items source. see the below line of code
          if ( arrayUtils.indexOf(f.split("_"), "NAME") == -1 ) { // exclude attrs that contain "NAME"
            fieldNames.items.push({ "name": app.fields[f], "value": f });
It is excluding/skipping for STATE_NAME & NAME, to be more precise, if any field name, contains word NAME after splitting with '_' as delimiter. So the name fields will not be part of dropdown list. For identify apart from template, you also need to look at below line of code where the title is being set for info window.
            var name = evt.graphic.attributes.NAME + " County",
                 ca = app.currentAttribute,
                 content = app.fields[ca] + ": " + number.format(evt.graphic.attributes[ca]);
            app.map.infoWindow.setTitle(name);
Hope this carifies all your doubts.
thejuskambi
The app.fields does not contain sde.sde.AP_Const.asmbname. The dropdown is populated is being populated by below code and it used app.outFields to iterate through the app.fields collection.
var fieldNames, fieldStore, fieldSelect;
        fieldNames
= { "identifier": "value", "label": "name", "items": []};
        arrayUtils
.forEach(app.outFields, function(f) {
            fieldNames
When i add "sde.sde.AP_Const.asmbname"  to out fields, drop down not working, It only showing the initialized field based rendering but showing an error with filtering Select in the console.
the dropdown list is almost disabled.
where am i going wrong.
satya
thejuskambi
you need to add both field name and label with collen delimited like
but, then the dropdown will show this value also, If you dont want it to show in need to ensure you dont add it to the fieldNames.items.
its working quite well here
Generate renderer | ArcGIS API for JavaScript
app.outFields = ["POP2007", "POP07_SQMI", "WHITE", "BLACK", "AMERI_ES", "ASIAN", "HAWN_PI", "OTHER", "MULT_RACE", "HISPANIC", "STATE_NAME", "NAME"];
My version
when i add this sde.sde.AP_Const.asmbname
when i remove the sde.sde.AP_Const.asmbname from outfields  everything works fine but the identity does not reflect the sde.sde.AP_Const.asmbname name.
satya
thejuskambi
Hello Satya,
I have been explaining the same thing as mentioned earlier. Adding only the new fields in app.outFields will cause problems as they are using that variable to populated the dropdown. That means you would also need to add a corresponding value to app.Fields collection as well. Please note that the app.Fields is a name value object like below.
app.fields = {
so along with adding "sde.sde.AP_Const.asmbname" to app.outFields. you need to add "sde.sde.AP_Const.asmbname" : "asmbname".
As far as Identify is concerned only the app is set up to show only the selected attribute value as per the below mentioned code.
            app.map.infoWindow.setContent(content);
Hope this was helpful and if you are still not able to fix it then please send the complete code and I shall take a look at it.
Hi thejus kambi,
I did get you. But my question is as in the example
app.fields does not conatin  "STATE_NAME", "NAME"
but app.outFields does have "STATE_NAME", "NAME"
which is used in
layer def
         app.layerDef = "STATE_NAME = 'Washington'";
as well as  pop up definition
          app.popupTemplate = new PopupTemplate({
          title
: "{NAME} County",
which when i use
is not working why so ?
app.fields = {
"POP2007": "Population(2007)", "POP07_SQMI": "Population/Square Mile(2007)",
"WHITE": "White", "BLACK": "Black", "AMERI_ES": "Native Americans",
"HISPANIC": "Hispanic", "ASIAN": "Asian", "HAWN_PI": "Native Hawaiian/Pacific Islander",
"MULT_RACE": "Multiple Races", "OTHER": "Other"
        app
.map = new Map("map", {
          center
: [-123.113, 47.035],
          zoom
: 7,
          slider
: false
var basemap = new ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/World_Terrain_Base/MapServer");
        app
.map.addLayer(basemap);
var ref = new ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/Reference/World_Reference_Overlay/MapServer");
        app
.map.addLayer(ref);
// various info for the feature layer
        app
.countiesUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2";
        app
        app
        app
.currentAttribute = "POP2007";
        app
          title
: "{NAME} County",
          fieldInfos
"fieldName": app.currentAttribute,
"label": app.fields[app.currentAttribute],
"visible": true,
"format": { places: 0, digitSeparator: true }
          showAttachments
:true
Satya.
thejuskambi
Satya,
Hi thejus kambi,
Got it now.
Thanks ,
Satya
