QML Calendar type - how to install/update to QtQuick.Controls 1.4
3498
07-12-2015 10:34 PM
by Anonymous User
Not applicable
Hi All
AppStudio currently installs with QtQuick.Controls 1.1
Version 1.4 has apparently introduced a Calendar type which I'd like to use.
Does anyone know how or whether I can update/install v1.4 of QtQuick.Controls? If it is possible, what is the process?
Cheers,
-Paul
GarethWalters
Hi Paul,
The QuickReport uses the calendar control. It was introduced at 1.3. You should simply change your import statement (even though you don't see it in the list).
Let me know how you go.
Cheers,
Gareth
GarethWalters
Hi Paul,
Cheers,
Gareth
by Anonymous User
Not applicable
Thanks Gareth for pointing that out! My code by default was at 1.1, the stuff I found online mentioned 1.4 (which wouldn't run) and I didn't think to try the versions in between.....
Runs fine using 1.3 as suggested.
Cheers,
-Paul
