summarize the attribute values of lines (in one layer) which have the same start- an endpoint
4417
13
06-23-2015 06:38 AM
JohannesUhl1
Do you know whether it is possible to summarize the attribute values of lines which have the same start- an endpoint?
This is my sitaution: I have ONE layer with lots of buslines between german cities. Now I want ArcGIS to summarize all lines which run between two cities to one line with the summarized frequentation attribut value. An this for all city to city relations.
Example - actual date situation:
Line 1: Stuttgart-München -> 5 times a week
Line 2: Stuttgart-München -> 2 times a week
Line 3: Stutgart-Hamburg -> 3 times a week
Line 4: Stutgart-Hamburg -> 3 times a week
Line 5: Stutgart-Hamburg -> 3 times a week
Result shall be:
one line between Stuttgart and München with attribut value 7 times a week and one line between Stuttgart and Hamburg wit attribut value 9 times a week.
I already tried lots of options, but none worked (including Dissolve).
Thank you very much for ideas,
Johannes
SepheFox
You might try using the summary statistics, but use the shape_length field as the case field. It is unlikely that you have the same length for features that are not coincident.
SepheFox
It would be easier to answer if I could see a screenshot of your table, with the fields and attributes, but assuming you have fields of start/end, and times per week, you could use the summary statistics tool to obtain the sum of times per week, with the start/end as a case field. If the start and end are different fields, you will need to add a new field and calculate it to have both values in it.
JohannesUhl1
Thank you very much for your anwer.
I guess your idea doesn´t work, because the table doesn´t include any start- an endpoint information. This information is only included in the shapefile, but not shown in the table. In my opinion it´s not possible to work with the data in the table. Thats why I guessed it´s neccessary to work with the spatial data.ot:
To the screenshot:
"Fahrten_Wo" is the number of times per week. All other columms are not used. I already splitted up the entire buslines to lines between single cities. Thats why you see the line "EU 2060 Mannheim-Kosice" 8 times: its sepated by the intermediate stops (Mannheim-Stuttgart (FID 1), Stuttgart-München (FID 2), and so on). But this names of the intermediate stops are not in the table
SepheFox
I'm sorry, I don't really understand what you're saying. Your original question didn't mention a table different from your shapefile. I can't really help you in less I'm clear what you are working with.
JohannesUhl1
Sorry, im quiete new in working with GIS.
The table and the shapefile aren´t different. What I just wanted to say is, that there aren´t any position data (like koordinates or citynames) in the table. That´s why I thought your idea can´t work.
SepheFox
So what is the field called "Liniename"?
JohannesUhl1
The field called "Linienname" ist just the name of the WHOLE line. It consist oft the linename/number itseslf and the very first city and the very last city. Thats why I can´t use this field: I want to know the sum of all runs a week (sum of several companies) between two cities in Germany. Would I just use the cities named in the field "Linienname" I would ignore the connections between the intermediate stops of the lines.
By the way: Thank you very much for your patience!
SepheFox
JohannesUhl1
Thank you very much for this creative idea. I will try 🙂
NICOLAPEDDIS
Sephe, the "Liniename" means-->> "line name". It's like a bus route name
