SOE Could not support extra jar ?
3551
11-07-2010 11:15 PM
ShubinLiu
     I deployed a SOE which used jdbc jar in the code , I export the jdbc jar in the SOE jar,and register sucessfull in ArcGIS Server manger, but when debug it ran into the following error "Can not load JDBC driver class oracle.jdbc.driver.OracleDriver".
     I Guess it can not find the extra jar like jdbc jar, where should I take the JDBC Jar to? Or SOE can not support extro Jar?
    Thank you for any informations!
TomSchuller
Hy,
what is your content in the MANIFEST.MF file of the SOE.jar.
It should be look like:
Class-Path: jdbc.jar
Your "jdbc.jar" file should be located in the same directory as your SOE.jar file:
<AGSHome>\java\lib\ext
Depending on the jdbc-driver, you have to invoke a Class.forName(..) or DriverManager.registerDriver(..)
Tom
ShubinLiu
Solved! Thanks much to Tom!
Add the manifest when I export the SOE Jar, it can run.
In manifest:
Manifest-Version: 1.0
Class-Path: ojdbc6.jar
Put the ojbc6.jar in \lib\ext folder .
Thanks, Tom!
