ArcGIS server (Preview the published mxd + ArcGIS server manager)
2877
07-10-2010 01:45 AM
JamalNUMAN
Legendary Contributor
I couldn't find the ArcGIS server manager, what is the reason?
I've published *.mxd file, but there is no thing in the preview, why?
Please, see the attached images that shows me question
Jamal Numan
by Anonymous User
Not applicable
Original User: vipulbhatia
- Please check your install media and make sure you have installed the web components.
- In arccatalog, you could not see the data probably not correct permissions to ArcGISSOC account for access to data in mxd. Check server documentation on publishing map services.
KevinHibma
Along with Vipul's post regarding:
"Please check your install media and make sure you have installed the web components"
.....you probably dont have IIS installed on the machine. Without IIS the Manager and Services Directory wont install. This would have been a warning that you could skip through during the AGS install.
You'll have to install IIS from ADD/Remove Programs > Windows Components
Then go back and do a either a modify OR a remove then re-install of AGS.
...and then of course there's the display problem which could be permissions like he said, or various other issues. However I'd get IIS working first, that may fix the second problem if its a simple display/virtual directory issue
