Adding Text for multiple Feature Layers using TextSymbol - Can't figure out.
3736
06-02-2015 03:35 PM
JohnRitsko
Scenario,
  I have a map which I'm trying to show Elected officials who reside over certain areas.  I have 5 different groups (Congress, Senate, Commission, Assembly, and Ward).  The first one you select with the checkbox works fine, labels good enough for what I need it to do.  However, when you select the next Elected type it hides the previous one and then symbolizes the featureLayer correctly but just no text when I try to add it to the map.  Any help with getting this working would be greatly appreciated.
Here is the function that I call to do this text labeling:
function labelElecteds(elc) {
        var electedColor = new Color("#000");
        var electedLabel = new TextSymbol().setColor(electedColor);
        electedLabel.font.setSize("12pt");
        electedLabel.font.setFamily("Calibri");
        var electedLabelRenderer = new SimpleRenderer(electedLabel);
        var labels = new LabelLayer({ id: "labels"});
        labels.addFeatureLayer(elc,electedLabelRenderer, "{NAME}");
        map.addLayer(labels);
RobertScheitlin__GISP
John,
  You need to remove the old label layer before you add a new one.
        var lyr = map.getLayer("labels");
        if(lyr){
          map.removeLayer(lyr)
        var labels = new LabelLayer({ id: "labels" });
        labels.addFeatureLayer(elc, electedLabelRenderer, "{NAME}");
John,
        if(lyr){
JohnRitsko
Robert,
  As always, you come through.  I had a feeling this was what I had to do and even tried putting in the removeLayer but couldn't quite get it.
Thank you so much,
John Ritsko
