Is there a way to embed a web page in Microsoft Word?
7963
05-28-2015 08:25 AM
ChrisSergent
I may want to share one of my Esri JavaScript API web apps. Is it possible to embed it in a Word document to see it live in the document, but to use the document to explain it?
BillDaigle
Not that I know of.  I've shared web maps with added narrative using Survey Monkey. In my case, I needed to get feedback on the map, so survey monkey worked quite well.
SteveCole
Honored Contributor
I've worked with inserting a map within MS Access forms using Microsoft's ActiveX web control and it works. I imagine you could do the same within Word. The one potential pitfall is that the web control i believe is based on Internet Explorer 8 so you may experience some issues thanks to the non-standard nature of older versions of Internet Explorer. You might want to test the functionality first if that might be a problem.
