ArcGIS Pro - creating macro
5120
05-27-2015 06:33 AM
BryanMager
If anyone has a suggestion, I work for a midsize corporation and there's often a need for maps but more specifically maps that have been refreshed with new data points. Is it possible, using ArcGIS Pro, to create a macro (of sorts) that will allow my customer to update the data points and refresh the map without my involvement (other than initial training). For this discussion, the map would contain the company market area (Maryland), counties, 300 data points, title, and legend. Thanks for your help, Bryan
YovavZohar1
Hi Bryan,
I'm not a code specialist, but as far as I know, you have several options without twiking with the PRO SDK:
all the above methods are semi-automatic, since they demand at least one intervention by the user in order to activate/run the workflow.
In order to fully automate the workflows, you might try "Schedulling a python script or model to run at prescribed time". I don't know how that fits the Pro - maybe someone with experiance/knoledge would comment here.
Good luck
YovavZohar1
Hi Bryan,
Good luck
BryanMager
thank you
