ArcGIS Pro Table Joins vs. ArcMap
2299
10-02-2015 07:41 AM
roemhildtg
I'm used to ArcMap, where you can have several 'copies' of a layer and each one has its own properties like Joins. It appears however, in Pro, when you join Layer A with Table A, Layer B (copied from Layer A) also gets that join.
Lets take two parcel layers each with the same data source FileGDB.gdb/parcels. Join one with a table, and Uncheck "Keep all Target Features".
Parcel layer 1 only shows the parcels that match with the table, but Parcel layer 2 is also now joined and only shows the features that joined. Is there any way to prevent this, so that Parcel Layer 2 shows all of the parcels, while Parcel layer 1 is only showing the joined rows?
