Update geometry then database has the same geometry two
4218
05-21-2015 08:34 PM
xiaoyunnsongb
Hello every  superiors:
            when I  move a  graphic geometry  to another place , then i use this js
     currentFeatureLayer.applyEdits(null, [evt.graphic], null,function(result){
                    createLog(logObj);
                   },function(err){
                    flag4log = -1;
to  update databse ,then  the graphic geometry record   become  two row  in  oracle database, the two record  all colums  the same。
hope you can help me ,thanks very much 。
OwenEarley
Does the evt.graphic have an Object ID for a feature that exists in your data set?
applyEdits(adds?, updates?, deletes?, callback?, errback?)
Apply edits to the feature layer. Only applicable for layers in a feature service.
<Graphic[]> updates
Array of features whose geometry and/or attributes have changed. Features must have a valid OBJECTID.
You can check this by logging the evt.graphic:
console.log(evt.graphic);
OwenEarley
<Graphic[]> updates
xiaoyunnsongb
Dear Mr. oearley
          Thanks very much for your answer.
The objectid really has the same ,but the objectid is auto create by
SELECT registration_id FROM sde.table_registry WHERE table_name = 'RESOURCEALARM' and owner = 'SDE';
I don't know how can it has same.
