Event after setDefinitionExpression has been applied
4165
05-21-2015 07:36 AM
StasyGrayn
Hi all.
I'm applying filters to a few layers at runtime like this:
layer.setDefinitionExpression();
I'd like to catch the moment, when the changes has been applied (because, as it seems, they are applied with some delay).
Can anyone advise me on how can I do that?
Thanks!
TimWitt2
Hey Stasy,
do you apply this before the layer is drawn the first time or has the layer been in your map  for a while?
If it is after, you can use the update-end event, which will fire after your layer has been redrawn.
Tim
TimWitt2
Hey Stasy,
Tim
StasyGrayn
Hello, Tim!
Thanks for the answer! I was trying that event and it hasn't worked untill I was re-checking it to post here as answer. Maybe some tricky typo or anything like that.
One more thank for the fast answer
TimWitt2
No problem! Glad I could sorta help
