F5 Setup with ArcGIS Server
4971
05-20-2015 09:39 AM
SonyaCowper
Looking to set up BIG IP with ArcGIS for Server 10.3.  Right now can't see the rest services properly. Can reach the arcgis/rest/services, but can not see the images.  Any suggestions?
GISSupport3
Can you please be a bit more specific ... what images can't you see?
Are you using a web adaptor?
What errors do you see in Fiddler?
Are you using APM?
SonyaCowper
Can't see the map image.  When you try and access the service through the url, the map image will not come up.  We are using a web adaptor and we are using https.
There are no errors in Fiddler.  The request is made, but just doesn't come back.
Looking for advice on how to properly set BIG IP up so it can handle the request to ArcGIS Server.
What is APM?
GISSupport3
I still am unclear what isn't being accessed.
You have an image service?
Other REST endpoints return correctly?
You are viewing via a browser or ArcMap?
That aside, there is nothing special to setup F5 for ArcServer.
Treat the same as any other https servers you have running.
Access Policy Manager is a F5 module.
