dropdowns and checkboxes make the map shift up
4634
05-15-2015 01:30 PM
RobertKirkwood
when the application is viewed at 1024 x 600 for example,  the dropdown menus and check boxes (when selected) cause the map to shift up. here is a link to the application:
WyWCW Atlas
I know this has something to do with CSS but cannot figure out why ow what is causing the problem. Anyone have any ideas? Thanks ahead of time!
Tags (4)
thejuskambi
Not sure whats causing the problem. I find that the map is not actually shifting but the banner image is being moved. just a couple of suggestions. Try to have the map also inside a contentpane with region set to center
or
set the top of the map top to 35px so that map does not overlap the title.
orsee if reordering the elements in the html helps. i.e. move the map div after the other divs
Hope it helps.
thejuskambi
or
Hope it helps.
RobertKirkwood
I made the Banner "fixed" position in the CSS and that corrected the problem
