Get selected menu option from context menu
4579
05-14-2015 10:52 AM
soniadickerson1
I'm converting a 9.3.1 esri desktop extension to a 10.2.2 addin and have a split tool that leaves a temporary line when the user right-clicks in the map to get the context menu and selects the delete sketch option.
This is what it leaves:
Here's the context menu
How do I tell when the user selects the delete sketch option from this menu?
Thanks very much.
Sonia
TeroRönkkö
I am not sure what you are asking - do you want to catch event that happens WHEN the user presses that button? or when the magic happens?
ArcObjects 10 .NET SDK Help
DuncanHornby
MVP Notable Contributor
To add to Tero's question, the first image above it looks like a graphic has been drawn not a sketch, which is it?
soniadickerson1
When the user selects the delete sketch option, I want to call the OnDeactivate method which just clears all of the variables and refreshes the view.
Duncan asked about the image- yes, the line is a sketch.
soniadickerson1
Here’s what I needed to do to fix the tools so that I'd get the correct menus and so the tool sketch would work properly.  I deprecated the old ones and built new ones with the coaching of one of the ESRI staff, Yuan.  Yeay for Yuan!
Right-click on the project and Add an item.  Select the ArcGIS desktop addins and then select the Add-in component.
Select the construction tool.  For this particular tool I set it up to be a polyline.
Then add the custom methods to the tool methods.
