I have one small question , I have main esri map in html page how to take this map control in module js page
5265
05-14-2015 04:19 AM
SadanandacharB1
html page has esri main map and in module js i am doing query task and calling that module function from html page ,
But i am not able to show the query task results, How to take html map control in module as we do in silverlight . my code is below, Please correct me
TEST.HTML
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <title>Dojo Modules</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
    <style>
      html, body, #mapDiv { height: 100%; width: 100%; margin: 0; padding: 0; }
    </style>
<script>var dojoConfig = {
    parseOnLoad: true,
    packages: [{
        "name": "modules",
        "location": location.pathname.replace(/\/[^/]+$/, "") + "/modules"
    </script>
    <script src="http://js.arcgis.com/3.8/"></script>
    <script>
        require([
        "dojo/dom",
        "dojo/dom-construct",
        "esri/map",
        "modules/myModule",
        "esri/layers/DynamicMapServiceLayer",
        "dojo/domReady!"
        ], function (
         dom,
         domConstruct,
         Map,
         myModule,
         DynamicMapServiceLayer) {
            var map = new Map("mapDiv", {
                // center: [-122.41, 37.78],
                zoom: 15,
                //  basemap: "topo"
            var mapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://XXX/arcgis/rest/services/TEST/MapServer");
            map.addLayer(mapServiceLayer);
            var mapServiceLayer1 = new esri.layers.ArcGISDynamicMapServiceLayer("http://XXX/arcgis/rest/services/TEST1/MapServer");
            map.addLayer(mapServiceLayer1);
            dojo.connect(map, 'onClick', function ()
              myModule.queryStatesLayer();
    </script>
</head>
<body id="mapDiv">
    <form id="form1" runat="server">
     <div ></div>
    </form>
</body>
</html>
myModule.is
define(["dojo/_base/declare", "dojo/_base/lang", "dojo/dom", "dojo/on","esri/map", "esri/tasks/QueryTask",
              "esri/tasks/query",
              "esri/symbols/SimpleMarkerSymbol",
              "esri/InfoTemplate",
              "dojo/_base/Color", "dojo/ready"],
        function (declare, lang, dom, on, Map, QueryTask, query, SimpleMarkerSymbol, InfoTemplate, Color, ready)
            var myModule = {
            //return
                queryStatesLayer : function()
                    queryTask = new QueryTask("http://XXX/arcgis/rest/services/TEST/MapServer/2");
                    query = new esri.tasks.Query();
                    query.returnGeometry = true;
                    query.outFields = ["NAME"];
                    query.where = "NAME = 'ambur'";
                 //   queryTask.execute(query, showResults);
                    queryTask.execute(query, function (queryResults) {
                        debugger;
                        Map.graphics.clear();
                        var resultFeatures = queryResults.features;
                        var extent = esri.graphicsExtent(resultFeatures);
                        if (!extent && features.length == 1) {
                            // esri.getExtent returns null for a single point, so we'll build the extent by hand
                            var point = features[0];
                            extent = new esri.geometry.Extent(point.x - 1, point.y - 1, point.x + 1, point.y + 1, point.SpatialReference);
                        //Loop through each feature returned
                        for (var i = 0, il = resultFeatures.length; i < il; i++) {
                            //Get the current feature from the featureSet.
                            //Feature is a graphic
                            var graphic = resultFeatures;
                            graphic.setSymbol(symbol);
                            //Set the infoTemplate.
                            graphic.setInfoTemplate(infoTemplate);
                            //Add graphic to the map graphics layer.
                            Map.graphics.add(graphic);
                            selectedWell = graphic.geometry;
                            //Zoom To a Layer...
                            //            var taxLotExtent = graphic.geometry.getExtent()
                            //                map.setExtent(taxLotExtent);
                        if (extent) {
                            // assumes the esri map object is stored in the globally-scoped variable 'map'
                            Map.setExtent(extent)
             //initialize InfoTemplate
                    infoTemplate = new esri.InfoTemplate("${NAME}", "NAME : ${NAME}<br/>");
                    //create symbol for selected features
                    symbol = new esri.symbol.SimpleMarkerSymbol();
                    symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE);
                    symbol.setSize(10);
                    symbol.setColor(new dojo.Color([255, 255, 0, 0.5]));
            return myModule;
ChrisSmith7
Honored Contributor
Have a look at my answer in this thread:
RequireJS and ArcGIS API for JS
I believe this may help you out a bit.
RobertScheitlin__GISP
Sadanandachar,
  You need to make your map var global in the html ( line 31 below):
<!DOCTYPE html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
  <style>
    html,
    body,
    #mapDiv {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script>
    var dojoConfig = {
      parseOnLoad: true,
      packages: [{
        "name": "modules",
  </script>
  <script>
    var map;
    require([
      "dojo/dom",
      "esri/map",
      "modules/myModule",
      "dojo/domReady!"
      ], function (
      dom,
      domConstruct,
      Map,
      myModule,
        zoom: 15,
        //  basemap: "topo"
      dojo.connect(map, 'onClick', function () {
  </script>
</head>
<body id="mapDiv">
  <form id="form1">
    <div></div>
  </form>
</body>
</html>
Then here is your module code cleaned up a little, and referencing the correct global map object:
        "dojo/_base/lang",
        "dojo/dom",
        "dojo/on",
        "esri/tasks/query",
        "esri/geometry/Extent",
        "esri/graphicsUtils",
        "dojo/_base/Color"],
  function (declare, lang, dom, on, QueryTask, Query, SimpleMarkerSymbol, InfoTemplate, Extent, graphicsUtils, Color)
    var myModule = {
      queryStatesLayer: function () {
        var queryTask = new QueryTask("http://XXX/arcgis/rest/services/TEST/MapServer/2");
        var query = new Query();
        query.outFields = ["*"];
        query.where = "PPIN = '1998'";
          //debugger;
          map.graphics.clear();
          var extent = graphicsUtils.graphicsExtent(resultFeatures);
          if (!extent && resultFeatures.length == 1) {
            var point = resultFeatures[0];
            extent = new Extent(point.x - 1, point.y - 1, point.x + 1, point.y + 1, point.SpatialReference);
            map.graphics.add(graphic);
//            selectedWell = graphic.geometry;
          if (extent) {
            map.setExtent(extent);
        var infoTemplate = new InfoTemplate("${NAME}", "NAME : ${NAME}<br/>");
        var symbol = new SimpleMarkerSymbol();
        symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
        symbol.setSize(10);
        symbol.setColor(new Color([255, 255, 0, 0.5]));
    return myModule;
