Information Lookup Application not using my geocoder
4362
05-12-2015 02:08 PM
LindseyStone
I am trying to create a web application ONLINE using ESRI's Information Lookup Web Application with my geocoder that I have uploaded to my Online Account.  When I create, and edit and then view the application it uses both my gedocder and ESRI World GeoCoder, which I both have listed under my Utility Services in my account.  However, as soon as I log out and test the application it is only using ESRI's.  This is the first time I have used a custom geocoder via Online.  Am I doing something wrong when creating the application or does the default ESRI applications not allow the use of our geocoders?  Website can be viewed at Information Lookup.
MarkLane
Lindsey, did you find a solution to your question?  I seem to be having the same issue.
KellyGerrow
Esri Alum
Can you share your application?
