Populate one field based on second
1347
11-04-2010 06:54 AM
PamelaLinson-DeVore
This may be simple but I am only a beginner.  Does anyone have a Python script to populate a field based on the code of another field in the same table?  Or do have any recommendations where I might find a script?
Thank you
Pam
curtvprice
This can be done a lot faster by using the CalculateField tool than with a cursor:
Expresson: NEWFIELD =
f(!CODEFIELD!)
Code block:
def f(code):
  codelist = ['a','b','c']
  valuelist = [10,20,30]
  value = valuelist[codelist.index(code)]
  return value
Language: "PYTHON"
But I need to say that generally the best way to do this is to have a lookup table and use a join and Calculate Field to calculate values over.
RandyKreuziger
Hi Pam,
  Welcome.  Try posting your question under the geoprocessing forum.  This forum is more for asking questions about ESRI Map Data.
StephenBarrow
Thank you
Pam
Hi Pam
In python use an updateCursor to access and update the rows then work row by row making your changes as required.  Here is something to get you started:
import arcpy
cur = arcpy.UpdateCursor(r"c:\your file") #put in your file path here
for row in cur:
  row.fieldName1 = row.fieldName2  #here I am copying the data from one field to another, just add your own code here.
  cur.updateRow(row) #transfer the row changes from memory to the table
Hope this helps
Stephen
curtvprice
f(!CODEFIELD!)
Code block:
def f(code):
  return value
Language: "PYTHON"
