Searching in Web AppBuilder for ArcGIS
4837
6
05-13-2015 08:50 AM
JustinNettleton
I am using the ArcGIS online version of Web AppBuilder. I have a simple application set up for County facilities. I am looking for a quick an easy way for users to search for facilities. A drop down of some sorts would work the best. I tried to use the filter widget, but I don't like the way its set up. It doesn't seem to make the process easy for the user at all. I may just be making the process harder than it needs to be.
So, is there any quick way to search or set up a drop down? I am just looking for the user to hit a button and their options pop up. They click on the facility they want and it zooms to it or highlights it on the map.
Justin Nettleton, GISP
RobertScheitlin__GISP
Justin,
   You might also consider building a geocode (single field) service that way you can just use the Geocoder widget to type the search term into.
RickeyFight
MVP Regular Contributor
Justin,
Have you considered the Bookmark widget? ​This would allow you to list the facilities and then zoom to their location.
JustinNettleton
Rickey,
I was actually just doing that as an alternative in case i didn't come up with a better solution.
Thanks for the response.
Justin,
JustinNettleton
Thanks, I will give that a try.
StanMcShinsky
​Justin,
Another way may be to set up a feature search on the web map in AGOL. This will allow you to search by features in the data that is using the actual data and not a cache of the data in a geocoding service. When you set this up in the web map in AGOL it will automatically show up as a drop down search in the geocoding search bar in WAB.
-Stan
JustinNettleton
Stan,
Thanks for the response. Looks like that is an option as well.
