Map.setBasemap function doesn't work as expected
3475
05-11-2015 07:53 AM
fuliaoli
I use Map.setBasemap function to change the basemap. The basemap is changed, but it changes back to the default if I pan and zoom out the map.  Is there a way to solve it, instead of use basemap gallery?
Thanks in advance,
li
fuliaoli
Thanks for your quick response.
There is not much code at all.
I declare a function and use a menu item to pass basemap name. That's it.
It seems to me that the default map object doesn't get swopped.
var selectBasemap = function(basemapId) {
  if (cwiMap.map.getBasemap() != basemapId) {
   cwiMap.map.setBasemap(basemapId);
Regards,
li
TimWitt2
Can you show us your code? It is hard to trouble shoot without seeing any code.
fuliaoli
Regards,
li
fuliaoli
My bad. I reset the default according to the current extent and forgot it.
